sketch command in vba
Message 1 of 8
hi
can someone help me on how to activate/execute 2dsketch command using vba?
it would be identical to just pressing the sketch button.
i need the code to add to the macro im creating.
thanks
Replies (7)
Message 2 of 8
ekinsb
Try this:
Public Sub ActivateSketch()
    Dim partDoc As PartDocument
    Set partDoc = ThisApplication.ActiveDocument
    ' Get the sketch to activate.  This
    ' uses the name of the sketch.
    Dim sk As Sketch
    Set sk = partDoc.ComponentDefinition.Sketches.item("Sketch1")
    ' Bring the sketch into edit mode.
    sk.Edit
End Sub
Brian Ekins
Mod the Machine blog
Message 3 of 8
.your code need the part to have existing sketch, am i right?
i need to do the 1st sketch , thats why i need to be able to launch the sketch command using vba.
Message 4 of 8
ekinsb
In order to active a sketch, it needs to exist. If you need to activate a sketch that doesn't exist, you'll first need to create it, which means you'll need some planar entity to create it on.  This can be a work plane or a planar face on the model.  Here's a version of the previous program that creates a new sketch on the X-Y base work plane and then activates it.
    ' Create a new sketch on the X-Y base work plane.
    Dim sk As Sketch
    Set sk = partDoc.ComponentDefinition.Sketches.Add( _
             partDoc.ComponentDefinition.WorkPlanes.item(3))
    sk.Edit
End Sub
Brian Ekins
Message 5 of 8
can i select the plane?
not hardcode it...
Message 6 of 8
GosponZ
I edit rule for i logic and working perfect. I fixed for x-z plane .
Message 7 of 8
ekinsb
Here's an example that allows you to select the plane.  It can be either a planar face on the part or a work plane.
Public Sub NewSketchOnPlane()
    ' Create a new sketch on a selected face.
    Dim planarEntity As Object
    Set planarEntity = ThisApplication.CommandManager.Pick(kAllPlanarEntities, _
                                                        "Select a face or work plane.")
    Dim sk As sketch
    Set sk = partDoc.ComponentDefinition.Sketches.Add(planarEntity)
    sk.Edit
End Sub
Brian Ekins
Message 8 of 8
GosponZ
Can you make this one in iLogic
