Simple iLogic Request - Copy Custom iProp to Real/Existing iProp
GKPByDesign
GKPByDesign
Hey,
I require an iLogic rule to grab a custom iProp and to copy it into an existing iProperty.
Custom iProp is Item_Type
Existing iProp is Project
I cannot remember how to do this, and I know it is very simple. The custom I prop is a multi value drop down value, would this be an issue?
Sergio.D.Suárez
Hello, here is a simple example to do what you need
	iProperties.Value("Project", "Project") = iProperties.Value("Custom", "Item_Type")
Then this would be another way to access what you're looking for
Dim oDoc As Document = ThisDoc.Document
' Get the PropertySets object.
Dim oPropSets As PropertySets
oPropSets = oDoc.PropertySets
oCustom = oPropSets.Item("Inventor User Defined Properties").Item("Item_Type").Value
oPropSets.Item("Design Tracking Properties").Item("Project").Value = oCustom
I hope it will be useful to solve your problem. regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
