iLogic Copy Value if between range otherwise leave blank
GKPByDesign
Message 1 of 8
GKPByDesign
I require two ilogic rules to be created that I simply cannot get my head round, I require these two rules to do the following:
Custom iProp Angle_1 entered by user,
If iProp Angle_1 is between 1-89 degrees the same value is copied to custom iProp Angle_2. eg Angle_1 = 56 Degrees then Angle_2 is the same at 56 degrees.
But if iProp Angle_1 is 1 or 90 degrees iProp Angle_2 remains blank (no text)
The second code:
Custom iProp Model_Type_1,
If Model_Type_1 is Model A,  Model B, Model C, or Model D, value for custom iProp Model_Type 2 will equal the same value. eg Model_Type_1 = Model B, Model_Type_2 also equals Model B.
But if Model_Type_1 is "None" (written as none) then Model_Type_2 is blank. (no text)
Can someone help me, I have just input over 2200 cell datas, my head is fried!
Replies (7)
Message 2 of 8
Sergio.D.Suárez
Hi, I think this rule does what you need. I have not tried it in depth. I hope it works well
If you have a property with a value of "59 gr", or "59 degrees", or "59 º". The rule will look for the space "" and separate the string to extract the number. Then compare this number and according to the conditions you mentioned you will overwrite the value of the second property.
Dim oDoc As Document = ThisDoc.Document
Dim oPropSets As PropertySets
oPropSets = oDoc.PropertySets
on error resume next
oCustomAngle_1 = oPropSets.Item("Inventor User Defined Properties").Item("Angle_1").Value
NumberAngle_1 = Left(oCustomAngle_1, (InStrRev(oCustomAngle_1, " ", - 1, vbTextCompare) - 1))
oExtension = Right(oCustomAngle_1, Len(oCustomAngle_1) - InStrRev(oCustomAngle_1, " "))
If 1 < NumberAngle_1 < 89 Then
	oPropSets.Item("Inventor User Defined Properties").Item("Angle_2").Value = NumberAngle_1 & " " & oExtension
If NumberAngle_1 = 1 Or NumberAngle_1 = 90 Then
	oPropSets.Item("Inventor User Defined Properties").Item("Angle_2").Value = "0 " & oExtension
 Regarding the second action I think that this rule could work.
If the first property says "None" it will put "" on the second property. If the first property has a value, it will place the same value in the second property
oModel_Type_1 = oPropSets.Item("Inventor User Defined Properties").Item("Model_Type_1").Value
If oModel_Type_1 = "Ninguno" Then
	oPropSets.Item("Inventor User Defined Properties").Item("Model_Type_2").Value = ""
Else
	oPropSets.Item("Inventor User Defined Properties").Item("Model_Type_2").Value = oModel_Type_1
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Message 3 of 8
GKPByDesign
Hey It is definitely doing something, but not do the second part
So the range I need is 0.5 - 89.5,
But if the values are 0.5 or 89.5 then the answer needs to be blank
eg,
Angle_1 = 46, Angle_2 = 46
OR
Angle_1 = 89.5, Angle_2 = (Blank) not zero
It doesn't seem to be doing this. I will look at the other code now.
Thank you
Message 4 of 8
GKPByDesign
The second code I do not need now, I have superseded it. But the angle one is still not leaving a blank value at two septic angles. Help please!
Range between 0.5 - 89.5 equal's the same value for a custom iprop
if 0.1 or 89.9 then value in custom I prop is blank.
Message 5 of 8
you  can make a range like this
I use a sample this should work...
dim myparam as Integer
myparam = InputBox("Prompt", "Title", "Default Entry")
If myparam > 100 And myparam < 150 Then
	MsgBox("happy")
Else
 MsgBox("bad luck")
Message 6 of 8
Sergio.D.Suárez
Hi, if the angle is written without your unit, only the numerical value, it is easier, you could use a rule like the one I show you below
On Error Resume Next
If 0.5 < oCustomAngle_1 < 89.5 Then
	oPropSets.Item("Inventor User Defined Properties").Item("Angle_2").Value = oCustomAngle_1
If oCustomAngle_1 = 0.5 Or oCustomAngle_1 = 89.5 Then
	oPropSets.Item("Inventor User Defined Properties").Item("Angle_2").Value = " "
Mechanical Designer
Message 7 of 8
GKPByDesign
I will try this tonight, I don't need the units so it may be a good solution
Message 8 of 8
Curtis_Waguespack
Hi @Anonymous
Welcome to the forum. You can use the "AndAlso" operator for this too.
https://docs.microsoft.com/en-us/dotnet/visual-basic/language-reference/statements/operator-statement
I hope this helps.
Curtis
oAngle_1 = iProperties.Value("Custom", "Angle_1")
If oAngle_1 >= 0.5  AndAlso oAngle_1 <= 89.5 Then
	iProperties.Value("Custom", "Angle_2") = oAngle_1
Else
	iProperties.Value("Custom", "Angle_2") = " "
