Show hide Assembly sketches on a drawing (IDW)
m.verbunt
m.verbunt
Hello all,
I am struggling to find the right way to get this iLogic code write. I did search a lot for some examples but none pointed me in the right direction. So hopefully someone here can help me out.
I have made an Assembly of a swimming pool. In this assembly I have created different sketches to represent possible plumbing setups. These sketches are at the top level of the assembly, so they are not part of any occurrences.
When in the drawing with the model selected, I can select 'Get Model Sketches'. Having done that the Assembly sketches become available in the drawing, and 'Include' will show the sketch in the drawing view.
No, I have eight possible sketches available:
Sketch 1a
Sketch 2a
Sketch 3a
Sketch 4a
Sketch 1b
Sketch 2b
Sketch 3c
Sketch 4c
The challenge I face is this: I want to in or exclude these sketches by use of iLogic. I can access the controlling parameter "Connection Point" from the assembly. These contain the eight options. I want iLogic to show the corresponding sketch in my drawing view which is on sheet "Customer" on "View1".
How can I achieve this? Any help would be greatly appreciated!
A.Acheson
Hi @m.verbunt
From this article which is actually for sub assemblies try this out. The sub assembly looping is removed and no need for proxy sketches. All sketches will be shown so you need to build in the logic for which sketch to show when.
        Dim oDrawingDoc As DrawingDocument
        If ThisApplication.ActiveDocument.DocumentType <>
           kDrawingDocumentObject Then
            MsgBox("need to make a drawing the active document")
        oDrawingDoc = ThisApplication.ActiveDocument
        Dim oView As DrawingView
        If oDrawingDoc.ActiveSheet.DrawingViews.Count < 1 Then
            MsgBox("Add a view to the drawing")
        Return
        oView = oDrawingDoc.ActiveSheet.DrawingViews(1)
        Dim oDoc As Document
        oDoc = oView.ReferencedDocumentDescriptor.ReferencedDocument
        If oDoc.DocumentType <> kAssemblyDocumentObject Then
            MsgBox("View's Referenced doc needs to be an assembly")
        Dim oAssy As AssemblyDocument
        oAssy = oView.ReferencedDocumentDescriptor.ReferencedDocument
        Dim oAssyDef As AssemblyComponentDefinition
        oAssyDef = oAssy.ComponentDefinition
        Logger.Info(oAssyDef.Sketches.Count)
        Dim oSketch As PlanarSketch
        For Each oSketch In oAssyDef.Sketches
           oView.SetVisibility(oSketch, True)
         Next
Regards
Alan
m.verbunt
Hi! Thanks for the quick repley. I will try this, and let you know the results.
Many thanks for taking the time to help me out. It's much appriciated!
m.verbunt
This doesn't seem to be working unfortunately. So I turned to ChatGPT to see if I could generate some code to push me in the correct direction. It looks like it got me pretty far, but there seems to be an error in line 25.
A bit more clarification about what I am trying to achieve.
I have an assembly with a swimming pool in it. At the top level of the assembly I have created eight sketches that represent the plumbing for different options. Our customers can chose at which corner the connection point (CP) will be located, and optionally we have a an extra option for each of those connection points.
The assembly holds the following parameters:
“ConnectionPoint” as a text parameter (CP1, CP2, CP3, CP4)
“Engels” as a Boolean parameter (True, False)
The sketches are:
“CP1“
“CP2“
“CP3“
“CP4“
“CP1 Engels“
“CP2 Engels“
“CP3 Engels“
“CP4 Engels“
Based on the selection of these parameters the correct sketch must been shown on the drawing (idw), the other sketches that do not correspond to these parameters need to be hidden.
In the drawing these sketches are already made available in the correct view. (“Get Model sketches”). Manually, I can include or exclude the sketches, but I would like iLogic to take care of this.
The sheet name of the drawing (idw) where the sketches must be made visible is “Customer:1” and the view name is “VIEW1”.
    Dim drawingDoc As DrawingDocument = ThisApplication.ActiveDocument
    Dim sheet As Sheet = drawingDoc.Sheets.Item("Customer:1") ' Replace "Customer:1" with the actual sheet name
    Dim view As DrawingView = Nothing
    For Each drawingView As DrawingView In sheet.DrawingViews
        If DrawingView.Name = "VIEW1" Then ' Replace "VIEW1" with the actual view name
            view = DrawingView
            Exit For
    Next
    If view IsNot Nothing Then
        Dim asmDoc As AssemblyDocument = TryCast(view.ReferencedDocumentDescriptor.ReferencedDocument, AssemblyDocument)
        If asmDoc IsNot Nothing Then
            Dim asmCompDef As ComponentDefinition = asmDoc.ComponentDefinition
            Dim connectionPoint As String = asmCompDef.Parameters.Item("ConnectionPoint").Value
            Dim engels As Boolean = asmCompDef.Parameters.Item("Engels").Value
            Dim sketchName As String = connectionPoint
            If engels Then
                sketchName = sketchName & " Engels"
            For Each sketch As Sketch In asmDoc.Sketches
                If Sketch.Name = sketchName Then
                    view.SetVisibility(sketchName, True)
                Else
                    view.SetVisibility(sketchName, False)
            Next
Any idea, how to fix this?
A.Acheson
Line 25 the assembly document does not contain the sketches collection. This is contained in the assembly component definition. The error message you would have received in the more info tab would likely have diagnosed this.
See the API help for AssemblyComponentDefintion.sketches property
Regards
Alan
