Can I place external rule directory on a server folder instead of the vaultworkspace
J.VandeMerckt
Message 1 of 23
J.VandeMerckt
Hi Forum
I was wondering if it is possible to place the external rule directory in a folder which is located on sharepoint instead of the vault workspace folder.
This way when making a new rule and/or form it doesn't have to be dragged into the vault to be visible for other users.
Sharepoint syncs these folders automatically unlike vault.
Will this work for rules and forms?
Br
Justin
Replies (22)
Message 2 of 23
Frederick_Law
It could fail when more then one user try to edit the file.
Also when Cloud sync, the file will be locked.
Usually happen when you're editing and saving the file.
I have them in Vault and Check it in after I updated.
Message 3 of 23
J.VandeMerckt
Not a lot of people work on them.
Very little chances of people working in the same Ilogic file.
Also;
How do you check in a external rule or global form.
The only way I know is to drag the file into vault.
So I thought a server might be easier since it syncs the folder.
Message 4 of 23
Frederick_Law
Only first time need to drag and drop.
Once it's in Vault, you can Check in and out there.
Of course user need to Get it after update.
Message 5 of 23
J.VandeMerckt
That's why I thought a server might be better so that it updates without people needing to manually get the file.
Is it possible for certain folders in the vault to be synced with all users every day. Or something similar.
Message 6 of 23
Frederick_Law
Message 7 of 23
Frederick_Law
https://www.synergis.com/2016/03/30/autodesk-vault-workspace-sync-workgroup-and-professional/
If you are going to be running the Workspace sync every week you can create a batch file to run the Workspace Sync through the command prompt. With a batch file you can add a task to the Task Scheduler to run without you having to do anything.
Message 9 of 23
Curtis_Waguespack
Hi @J.VandeMerckt
Yes, I've done this with a Sharepoint location in the past, seemed to work fine.
recall that that the Forms location is related to the Design Data folder.
....Design Data\iLogic\UI
that is set at: Tools tab> Application Options button> File tab > Design Data setting
I hope this helps.
Curtis
Message 10 of 23
Curtis_Waguespack
@J.VandeMerckt
Also this rule might be something to explore. This will add an external rule path to the configuration, based on the windows username.
So for instance my profile username on this machine is CurtisWaguespack, so this:
sUserName = Environ$("UserName")
'Add path to External iLogic rule folder for the project
oPath = "C:\Users\" & sUserName & "\MySharePointFolder\iLogic Rules"
returns: "C:\Users\CurtisWaguespack\MySharePointFolder\iLogic Rules"
where as another user's Username might be JohnSmith, so it would return
"C:\Users\JohnSmith\MySharePointFolder\iLogic Rules", on their machine.
'Get current list of External iLogic directories
Dim oExternalRuleDirectories As New List(Of String)
oExternalRuleDirectories.AddRange(iLogicVb.Automation.FileOptions.ExternalRuleDirectories)
If oExternalRuleDirectories.Contains(oPath) Then Exit Sub
If System.IO.Directory.Exists(oPath) Then
	oExternalRuleDirectories.Add(oPath)
iLogicVb.Automation.FileOptions.ExternalRuleDirectories = oExternalRuleDirectories.ToArray
Message 11 of 23
Frederick_Law
External Rules can be anywhere:
Message 12 of 23
Curtis_Waguespack
Indeed, they can. The reason people would use Sharepoint/Onedrive for this is that it can sync the external ilogic rules automatically.
So for instance, if I make changes to 8 rules, and they are synced to that folder automatically, the 30 users that I support who are spread out all over the world, will have the latest versions of those files when they are synced, without me having to remember to to tell them about the changes, and them having to remember to get those new versions from the Vault, etc.
I think generally, this works pretty well for files such as external rules, or Inventor templates, that are maintained by one person ( read/write) and used by many others ( read only).
Message 13 of 23
J.VandeMerckt
@Curtis_Waguespack Thank you for all the information, this all seems worth taking a look at.
You do mention that the Forms file is related to the design data folder, does that mean that forms are not able to be put on a sharepoint folder and external rules are? Or am I seeing this wrong?
Because if that's the case people would still need to check in and also get the forms manually when working with forms.
While the external rules will be synced.
Also good idea to do the same things for templates and styles and such. Definitely worth taking a look at.
Message 14 of 23
Curtis_Waguespack
Hi @J.VandeMerckt,
What I’ve done in the past is just put the entire Design Data folder in the shared location.
Message 15 of 23
J.VandeMerckt
Yes but we also work with the vault, so I don't think it works.
Message 16 of 23
Curtis_Waguespack
It's been several years, so maybe something changed, but that was a vaulted environment, and it worked. We didn't put the Design Data files in the Vault though.
Message 17 of 23
J.VandeMerckt
Ah but for what did you need the vault then?
Message 18 of 23
Curtis_Waguespack
All of our project design files went into the Vault ( meaning drawings, assembly, and part files. )
We managed and backed up our support files such as templates, design data, ilogic rules with server backed up locations.
Message 19 of 23
J.VandeMerckt
Ok, that's exactly what I was wondering.
Thank you
Message 20 of 23
Frederick_Law
I've Design Data, iFeature, iLogic and Template in Vault.
Other user need to "Get" them when they're updated.
I'm setting up "Workspace Sync" setting to keep them update and won't delete them on user computers.
