Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Show FILENAME without file format
JJ_PL
JJ_PL
Hello guys,
I would like to ask for help to display FILENAME in general note but without file format.
I do display it by showing standard iProperties : FILENAME general note...
I have tried to write short code to generate new property, but i don't know how to select FILENAME parameter
I think the way I try to do it is good, but can go over this problem and I can't find soulution in google
Would be greatful for tips
Regards
JJ
CCarreiras
Hi!
You can create a custom parameter to get the file name without extension, then add that parameter to the annotation.
' Get the full document file name (with extension)
Dim fullFileName As String
fullFileName = ThisDoc.FileName(True) ' True includes extension
' Remove the extension to get just the file name
Dim fileNameWithoutExtension As String
fileNameWithoutExtension = System.IO.Path.GetFileNameWithoutExtension(fullFileName)
' Set the Part Number to match the file name (no extension)
iProperties.Value("Custom", "FNnExt") = fileNameWithoutExtension
or just:
iProperties.Value("Custom", "FNnEXT") = ThisDoc.FileName(False)
CCarreiras
JJ_PL
thank you very much!
Regards
JJ
