SHEETMETAL FLAT PATTERN AUTO EXPORT API, ILOGIC
jaimin.ja.3
jaimin.ja.3
Add Export Batch Sheetmetal Flat Pattern to .dwg or .dxf format
Also add some features like Generate bending drawings
in which when we start exporting flat file it should open all the individual Sheetmetal parts one by one then put one flat file and, in another sheet, or the same sheet put 2 isometric views from LH & RH.
On the flat view add dimensions from cutting edge to bend lines (& give option to give notch "<>" at the bend)
and export it to PDF & >dwg with trimmed bend line.
mention required details like
1. Thickness of part
2. Material
3. bend table
4. Qty. used in assembly
A.Acheson
Hi @jaimin.ja.3
Is your post an idea or a request for help with automation? If it is a request for help I would suggest to add some code your working on to achieve your goal and where your needing help and or ask a specific question.
Regards
Alan
