SHEETMETAL FLAT PATTERN AUTO EXPORT API, ILOGIC
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Add Export Batch Sheetmetal Flat Pattern to .dwg or .dxf format
Also add some features like Generate bending drawings
in which when we start exporting flat file it should open all the individual Sheetmetal parts one by one then put one flat file and, in another sheet, or the same sheet put 2 isometric views from LH & RH.
On the flat view add dimensions from cutting edge to bend lines (& give option to give notch "<>" at the bend)
and export it to PDF & >dwg with trimmed bend line.
mention required details like
1. Thickness of part
2. Material
3. bend table
4. Qty. used in assembly
