Sheetmetal Export DXF flat pattern - using ilogic with custom cofiguration file
Greetings all,
I am in the process of setting up an export rule in ilogic and have followed the following:
https://forums.autodesk.com/t5/inventor-customization/ilogic-for-creating-flat-pattern-for-sheet-met...
This method works great however is there a way to define the config file?
I am assuming that it is somewhere in this string:
oDataMedium.FileName = oFolder & "\" & CustomName  & " " & oFileName & ".dxf"
Dim oCompDef As SheetMetalComponentDefinition
oCompDef = oDrawDoc.ComponentDefinition
If oCompDef.HasFlatPattern = False Then
oCompDef.Unfold
Else
oCompDef.FlatPattern.Edit
Dim sOut As String
sOut = "FLAT PATTERN DXF?AcadVersion=2010&OuterProfileLayer=OUT PRO"
oCompDef.DataIO.WriteDataToFile( sOut, oDataMedium.FileName)
oCompDef.FlatPattern.ExitEdit
Catch
End Try
We use dxf's for lasercutting and would like to be able to bulk export sheetmetal flat patterns without any fold lines or etch markings, just inner profile and outer profile
thanks in advance
Sergio.D.Suárez
Hi, in addition to the information that I shared in the other thread, here I leave you the material that appears in the programming aid of the inventor API, there you will find very useful information, I hope it helps you. Regards
Translate - Sheet Metal to DXF API Sample Description
The sample code below writes a sheet metal file out as DXF. DWG is also supported. Use either the FLAT PATTERN DWG or FLAT PATTERN DXF formats.There are several optional arguments that can be specified as part of the format string. E.g. 'FLAT PATTERN DXF?TangentLayer=Tangents&SimplifySplines=True'). Below are the names of these arguments and relevant default values. The output will use these values unless you override them as part of the input string.
ArgumentTypeDefault ValueNote
TangentLayerStringIV_TANGENT
OuterProfileLayerStringIV_OUTER_PROFILE
ArcCentersLayerStringIV_ARC_CENTERS
InteriorProfilesLayerStringIV_INTERIOR_PROFILES
BendLayerStringIV_BENDBendUpLayer + BendDownLayer (legacy support)
BendUpLayerStringIV_BEND
BendDownLayerStringIV_BEND_DOWN
ToolCenterLayerStringIV_TOOL_CENTERToolCenterUpLayer + ToolCenterDownLayer (legacy support)
ToolCenterUpLayerStringIV_TOOL_CENTER
ToolCenterDownLayerStringIV_TOOL_CENTER_DOWN
FeatureProfilesLayerStringIV_FEATURE_PROFILESFeatureProfilesUpLayer + FeatureProfilesDownLayer (legacy support)
FeatureProfilesUpLayerStringIV_FEATURE_PROFILES
FeatureProfilesDownLayerStringIV_FEATURE_PROFILES_DOWN
AltRepFrontLayerStringIV_ALTREP_FRONT
AltRepBackLayerStringIV_ALTREP_BACK
UnconsumedSketchesLayerStringIV_UNCONSUMED_SKETCHES
TangentRollLinesLayerStringIV_ROLL_TANGENT
***ColorString *** indicates name of layer from the argument column. RGB values separated by ;. Example: TangentLayerColor=255;0;0
***LineTypeLong *** indicates name of layer from the argument column. Long value from LineTypeEnum. Example: TangentLayerLineType=37644
***LineWeightDouble *** indicates name of layer from the argument column. Value in centimeters. Example: TangentLayerLineWeight=.1016
CustomizeFilenameString
AcadVersionString 2018, 2013, 2010, 2007, 2004, 2000, or R12 (for DXF only)
SimplifySplinesBooleanTrueEnable spline replacement by linear segments
SplineToleranceDouble0.01Chord tolerance for spline replacement
AdvancedLegacyExportBooleanTrue
MergeProfilesIntoPolylineBooleanFalseBuild a polyline of the exterior profiles
RebaseGeometryBooleanFalseMove geometry to 1st quadrant
InvisibleLayersString List of layer names to make invisible, separated by ;
Code Samples
The following sample demonstrates creating an R12 DXF file that will have a layer called Outer where the the curves for the outer shape will be created.
Public Sub WriteSheetMetalDXF()
    ' Get the active document.  This assumes it is a part document.
    Dim oDoc As PartDocument
    Set oDoc = ThisApplication.ActiveDocument
    ' Get the DataIO object.
    Dim oDataIO As DataIO
    Set oDataIO = oDoc.ComponentDefinition.DataIO
    ' Build the string that defines the format of the DXF file.
    Dim sOut As String
    sOut = "FLAT PATTERN DXF?AcadVersion=R12&OuterProfileLayer=Outer"
    ' Create the DXF file.
    oDataIO.WriteDataToFile sOut, "C:\temp\flat2.dxf"
End Sub
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
