more sort help.
more sort help.
Message 1 of 10
more sort help.
top level assm. would be 12345000
new parts would be 12345001 to 12345009
new sub assm. would be 12345010
reused parts would be 11111001 to 11111009
reused assm. would be 11111010
i need to get a total number of new parts with total weight from the model.
Replies (9)
Message 2 of 10
still having some trouble with this one. any help would be greatly appreciated.
Message 3 of 10
no longer need weight just a count of new parts. here's what i have so far. it seems to miss all the part numbers
Sub Main()
    ' Get the active assembly.
    Dim oAsmDoc As AssemblyDocument
    oAsmDoc = ThisApplication.ActiveDocument
	' Get the assembly component definition.
    Dim oAsmDef As AssemblyComponentDefinition
    oAsmDef = oAsmDoc.ComponentDefinition.iProperties.Value("Project", "Part Number")
	oNum = oAsmDef.iProperties.Value("Project", "Part Number",Left(12345000,5))
    ' Get all of the leaf occurrences of the assembly.
    Dim oLeafOccs As ComponentOccurrencesEnumerator
    oLeafOccs = oAsmDef.Occurrences.AllLeafOccurrences
    ' Iterate through the occurrences and print the name.
	Dim cnt As Integer
	cnt = 0
    Dim oOcc As ComponentOccurrence
	oOcc = oLeafOccs(iProperties.Value("Project", "Part Number",Left(12345000,5)))
    For Each oOcc In oLeafOccs
		If oLeafOccs = oNum Then
			cnt = cnt + 1
			MessageBox.Show(oOcc.Name)
    Next
	MessageBox.Show(cnt)
End Sub
Message 4 of 10
HideoYamada
Try this code (VBA).
The code counts the Parts which part number is started with "12345".
Option Explicit
' This Code is written in VBA.
Sub Main()
    Dim topAssyDoc As AssemblyDocument
    Set topAssyDoc = ThisApplication.ActiveEditDocument
    Dim count As Integer
    count = CountNewParts(topAssyDoc.ComponentDefinition.Occurrences)
    MsgBox "Count : " & count
End Sub
Function CountNewParts(occs As ComponentOccurrences) As Integer
    CountNewParts = 0
    Dim occ As ComponentOccurrence
    For Each occ In occs
        If IsNewPart(occ) Then
            CountNewParts = CountNewParts + 1
        ElseIf TypeOf occ.Definition Is AssemblyComponentDefinition Then
            CountNewParts = CountNewParts + CountNewParts(occ.Definition.Occurrences)
    Next occ
End Function
Function IsNewPart(occ As ComponentOccurrence) As Boolean
    IsNewPart = False
    If Not TypeOf occ.Definition Is PartComponentDefinition Then
        Exit Function
    Dim oPartDoc As PartDocument
    Set oPartDoc = occ.Definition.Document
    Dim partNumber As String
    partNumber = oPartDoc.PropertySets("{32853F0F-3444-11D1-9E93-0060B03C1CA6}")("Part Number").Value
    If Left(partNumber, 5) = "12345" Then
        IsNewPart = True
End Function
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
https://www.freeradical.jp
Message 5 of 10
that does count everything. is there a way to automatically extract the first 5 digits of the top level assembly for the search string? also i only need to count .ipt files that start with the first 5 digits of the top level assembly. this counts subassemblies as parts too. thanks for helping me with this.
Message 6 of 10
also i only need number of new part numbers created not number of new part occurrences. thanks for your help
Message 7 of 10
HideoYamada
Delete or comment out these two lines :
'        ElseIf TypeOf occ.Definition Is AssemblyComponentDefinition Then
'            CountNewParts = CountNewParts + CountNewParts(occ.Definition.Occurrences)
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
Message 8 of 10
HideoYamada
Ah, this needs a bit complex code. Just wait...
Freeradical
 Hideo Yamada
Message 9 of 10
HideoYamada
Hello Keith,
I translated the VBA code into iLogic because I want to use .Net Collection Library.
Option Explicit On
Sub Main()
    Dim topAssyDoc As AssemblyDocument = ThisApplication.ActiveEditDocument
    Dim newPartDocuments As New System.Collections.Generic.List(Of PartDocument)
    CountNewParts(topAssyDoc.ComponentDefinition.Occurrences, newPartDocuments)
    MessageBox.Show("Count : " + newPartDocuments.Count.ToString())
    newPartDocuments.Clear()
End Sub
Sub CountNewParts(occs As ComponentOccurrences, newPartDocuments As System.Collections.Generic.List(Of PartDocument))
            Dim oPartDoc As PartDocument = occ.Definition.Document
            If Not newPartDocuments.Contains(oPartDoc) Then
                newPartDocuments.Add(oPartDoc)
'            CountNewParts(occ.Definition.Occurrences, newPartDocuments)
    Next occ
End Sub
    IsNewPart = False
        Exit Function
        IsNewPart = True
End Function
This code reports the number of new part documents (not occurrences of new part documents).
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
Message 10 of 10
i made a little mod but your code works great. thanks for your help
Sub Main()
        Dim sSN As String
        sSN = InputBox("Please enter first five digits of parts you are interested in:", "Input needed", "xxxxx")
    CountNewParts(topAssyDoc.ComponentDefinition.Occurrences, newPartDocuments, sSN)
End Sub
Sub CountNewParts(occs As ComponentOccurrences, newPartDocuments As System.Collections.Generic.List(Of PartDocument), sSN As String)
        If IsNewPart(occ, sSN) Then
           CountNewParts(occ.Definition.Occurrences, newPartDocuments,sSN)
    Next occ
End Sub
