Sheet Supression based on text
staszakg
staszakg
To start, I am pretty new to iLogic. I am trying to create a iLogic rule that will suppress sheet 8 when the part number contains an "H". I want the sheet suppressed so I need to exclude both from printing & counting.
The "H" code is for an additional drill operation. If the part number does not contain the "H" I do not need the drawing sheet to be part of the package. The Part No is found in the iProperties Custom tab as shown
This is what I have but it returns "Line 1: End of statement expected."
If iProperties.Value("Custom", "PART NO") Contains("H") Then
	ThisDrawing.Sheet("Sheet:8").Sheet.ExcludeFromPrinting = True
	ThisDrawing.Sheet("Sheet:8").Sheet.ExcludeFromCount = True
 I saw another post that requested Sheet Suppression be added to Inventor as an option. It looks like it died due to a lack of votes.
Thanks in advance
Inventor Pro 2019 - 64 Bit
Vault Pro 2019
Intel Xenon CPU-E5-1650v3 @ 3.50 GHz
NVIDIA Quadro K2200
Windows 7 Pro (SP1)
Accepted solutions (3)
FINET_Laurent
Morning,
Maybe this does the job?
Dim oPartName As String = iProperties.Value("Custom", "PART NO")
If oPartName.Contains("H") Then
Else
	ThisDrawing.Sheet("Sheet:8").Sheet.ExcludeFromPrinting = False
	ThisDrawing.Sheet("Sheet:8").Sheet.ExcludeFromCount = False
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
bhavik4244
@staszakg
You may try the below code. Since it's accessing the file name itself so you don't have to care for iProperties of each part!
If it solves your purpose then please accept it as a solution.
Bhavik
LinkedIn
Dim oDrawingDoc As DrawingDocument
oDrawingDoc = ThisApplication.ActiveDocument
Dim oSheets As Sheets
oSheets = oDrawingDoc.Sheets
Dim oViews As DrawingViews
Dim oView As DrawingView
Dim oSheet As Sheet
For Each oSheet In oSheets
	oViews = oSheet.DrawingViews
	For Each oView In oViews
		Dim oModelDoc As Document = oView.ReferencedDocumentDescriptor.ReferencedDocument
		Dim oViewModelName As String = oModelDoc.DisplayName.ToString
		If oViewModelName.Contains("H") Then
		oSheet.ExcludeFromPrinting = True
		oSheet.ExcludeFromCount = True
		Else
		oSheet.ExcludeFromPrinting = False
		oSheet.ExcludeFromCount = False
		Next
	Next
Bhavik Suthar
WCrihfield
In your original post, the (iProperties.Value("Custom", "PART NO")) is understood as an Object, instead of a string, so you just needed to convert it to a string by either adding ".ToString" a the end of it or by enclosing it within the CStr() method.  Then you were missing the "." just before the Contains() method.  Although my code doesn't do anything differently than @FINET_Laurent 's code, it shows you two possible options for using the iProperty.Value() directly, as you were trying to do in your original code.  And it gets the sheet the natural way, instead of through the iManagedSheet route, and sets it to a variable, to help reduce code needed within the If...Then statement.
Just another couple of variations of how it can be done, for educational purposes.
Dim oS8 As Sheet = ThisDrawing.Document.Sheets.Item("Sheet:8")
If CStr(iProperties.Value("Custom", "PART NO")).Contains("H") Then
	oS8.ExcludeFromPrinting = True
	oS8.ExcludeFromCount = True
Else
	oS8.ExcludeFromPrinting = False
	oS8.ExcludeFromCount = False
or
If iProperties.Value("Custom", "PART NO").ToString.Contains("H") Then
Else
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click 'LIKE' 👍.
Wesley Crihfield
(Not an Autodesk Employee)
staszakg
Thank you all for your help. It works perfectly.
Vault Pro 2019
NVIDIA Quadro K2200
Windows 7 Pro (SP1)
