adding to joint command
rclement
rclement
what i would like to see in the joint command especially with slider is too be able to measure while in that command
si i dont have to measure then go back to add to limits or get out of it and put either a mate or flush command with it
maybe also with rotaional to measure angle not everything is 90 degrees to each other
mcgyvr
@rclement  Maybe you meant to post this in the ideastation?
https://forums.autodesk.com/t5/inventor-ideas/idb-p/v1232
