- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Could someone Please 🙏 modify the code below to use a custom i-property <MARK> in place of the ("Part Number")
and remove the ("Description")
thanks in advance.
Sub Main
If TypeOf ThisDoc.Document Is DrawingDocument Then
Dim dwgDoc As DrawingDocument = ThisDoc.Document
For Each dwgSheet As Sheet In dwgDoc.Sheets
If dwgSheet.DrawingViews.Count > 0 Then
modelFile = dwgSheet.DrawingViews(1).ReferencedDocumentDescriptor.FullDocumentName
modelDoc = dwgSheet.DrawingViews(1).ReferencedDocumentDescriptor.ReferencedDocument
prtNumber = modelDoc.PropertySets("Design Tracking Properties").Item("Part Number").Value & " - " & _
modelDoc.PropertySets("Design Tracking Properties").Item("Description").Value
If Not String.IsNullOrEmpty(prtNumber) Then
dwgSheet.Name = prtNumber
End If
End If
Next
End If
End Sub
