Sheet Numbering
Sheet Numbering
timothy_berg
Message 1 of 16
Sheet Numbering
timothy_berg
I have the code below to name the sheets for easy export to DWG.
SyntaxEditor Code Snippet
Dim oSheets As Sheets = ThisDrawing.Document.sheets
Dim oSheet As Sheet
Dim count As Integer
count=0
For Each oSheet In oSheets
    count+=1
    Page_Count=count
    'MessageBox.Show(Page_Count)
    oSheet.activate
    Dim oDrawingView As DrawingView = oSheet.DrawingViews(1)
    oModel = ActiveSheet.View(oDrawingView.Name).ModelDocument
    EquipName = oModel.PropertySets.Item("Inventor Summary Information").Item("Comments").Value
    EquipName1=Left(EquipName,3)
        ActiveSheet.Sheet.Name =EquipName1 & " S" & Page_Count
Next
 which provides a result of
001 S1
001 S2
002 S3
002 S4
My preferred result would be
001 S1
001 S1
002 S1
002 S2
In other words I want the "S""number" to count with the instance of the "EquipName1".
Replies (15)
Message 2 of 16
dgreatice
so in 1 sheet there are > 1 view and each view is difference component?
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
Message 3 of 16
chandra.shekar.g
Autodesk Support
Autodesk Support
@timothy_berg,
"EquipName1" seems unique in each sheet. Try below iLogic code.
ActiveSheet.Sheet.Name =EquipName1 & " S" & EquipName1
How to get instance of "EquipName1" ?
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 4 of 16
timothy_berg
Thanks for the reply
the count will be the number of instances of the same value coming from EquipName1 not the sheet number
001 S1:1
001 S2:2
002 S1:3
002 S2:4
003:5
004:6
005 S1:7
005 S2:8
005 S3:9
the EquipName1 would refer to the number of sheets it has, in 005's case i am providing 3 sheets etc.
Message 5 of 16
chandra.shekar.g
Autodesk Support
Autodesk Support
@timothy_berg,
Try below iLogic code to count instance of EquipName1.
Dim oSheets As Sheets = ThisDrawing.Document.Sheets
Dim oSheet As Sheet
Dim oList As ArrayList = New ArrayList()
    oSheet.activate
    EquipName1 = Left(EquipName, 3)
	oList.Add(EquipName1)
	Dim item As String
	Dim i As Integer
	For Each item In oList
	    If item = EquipName1 Then
	        i = i + 1
	    End If
	Next
	ActiveSheet.Sheet.Name = EquipName1 & " S" & i
Next
In this, it is considered single instance of EquipName1. It would results in below sheet names.
001 S1:1
001 S2:2
002 S1:3
002 S2:4
003 S1:5
004 S1:6
005 S1:7
005 S2:8
005 S3:9
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 6 of 16
timothy_berg
thanks for the reply i'm getting this result
001 S1:1
001 S3:2
002 S4:3
002 S6:4
Message 7 of 16
chandra.shekar.g
Autodesk Support
Autodesk Support
@timothy_berg,
Can you please share drawing file to test? Please make sure that files are non confidential.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 8 of 16
timothy_berg
files attached
Message 9 of 16
timothy_berg
files attached
Message 10 of 16
chandra.shekar.g
Autodesk Support
Autodesk Support
@timothy_berg,
Dim oSheet As Sheet
    oSheet.activate
	Dim item As String
	Dim i As Integer = 0
	        i = i + 1
	    End If
	Next
Next
Result of above code for attached sample drawing.
001 S1:1
001 S2:2
002 S1:3
002 S2:4
003 S1:5
004 S1:6
005 S1:7
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 11 of 16
timothy_berg
Thanks for the reply is there any way to get the code to only put the S count on the duplicate instance of the EquipName1. I've attached a screen shot of the desired result that I modified manually.
Message 12 of 16
chandra.shekar.g
Autodesk Support
Autodesk Support
@timothy_berg,
Try below iLogc code to get desired result. If desired result is achieved, click on "ACCEPT SOLUTION".
Dim oSheet As Sheet
    oSheet.activate
	Dim item As String
	        i = i + 1
	    End If
	Next
Next
For Each item As String In oList
	Dim itemName As String = item
	Dim itemCount = (From a As String In oList Select a Where a = itemName).Count
	If itemCount = 1 Then
		oName = item & " S1"
			oSheet.activate
			If ActiveSheet.Sheet.Name.StartsWith(oName) = True Then
				ActiveSheet.Sheet.Name = item
			End If
		Next
	End If
Next
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 13 of 16
timothy_berg
Thank you for helping me on this, I have this error message:
Error on Line 28 : Expression of type 'System.Collections.ArrayList' is not queryable. Make sure you are not missing an assembly reference and/or namespace import for the LINQ provider.
Message 14 of 16
chandra.shekar.g
Autodesk Support
Autodesk Support
@timothy_berg,
Linq is advanced technique to query duplicate count in ArrayList. It is supported in Inventor 2018. iLogic code is modified with simple technique to get duplicate. You can try below iLogic code to achieve desire result.
Dim oSheet As Sheet
    oSheet.activate
	Dim item As String
	Dim i As Integer =0
	        i = i + 1
	    End If
	Next
Next
	Dim itemCount As Integer  = 0
	For Each itemName In oList
		If item = itemName Then
			itemCount = itemCount + 1
		End If
	Next
			oSheet.activate
			End If
		Next
	End If
Next
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 15 of 16
timothy_berg
Thanks for figuring that out.
Message 16 of 16
timothy_berg
One more thing can the Active Sheet Name be displayed in the titleblock?
