Sheet Number in VBA
Sheet Number in VBA
stuartmp
Message 1 of 8
Sheet Number in VBA
stuartmp
Hi All
I was just wondering if it is possible to get the current sheet number through VBA?
Replies (7)
Message 2 of 8
The sheet number is appended to the sheet name in
the browser.  You can get this name using the Name property of the Sheet
object and then extract the number from the name.  Here's an example of a
function that does this.
Public Function GetSheetNumber(ByVal Sheet
As Inventor.Sheet) As Integer
    Dim strSheetName As
String
    strSheetName = Sheet.Name
    If InStr(strSheetName, ":")
Then
        ' Extract the sheet number
from the name.
        GetSheetNumber =
CInt(Right$(strSheetName, Len(strSheetName) - InStrRev(strSheetName,
    Else
' This sheet is not numbered so return
zero.
        GetSheetNumber =
0
    End If
End Function
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Hi
All I was just wondering if it is possible to get the current sheet number
through VBA? Thanks
Message 3 of 8
stuartmp
Thanks Brian.
I originally had.
Dim SheetNumber as string
SheetNumber = Mid(Trim(oActiveSheet.Name), 1 + InStrR(Trim(oActiveSheet.Name), ":", vbTextCompare))
Function InStrR(ByVal sTarget As String, ByVal sFind As String, ByVal iCompare As Long) As Long
Dim P As Long, LastP As Long, Start As Long
P = InStr(1, sTarget, sFind, iCompare)
Do While P
LastP = P
P = InStr(LastP + 1, sTarget, sFind, iCompare)
Loop
InStrR = LastP
End Function
' I did not realize until I just tried it that you can not override the sheet number manually in the browser. It does not accept you renaming it to
Test:2 for example. I guess I should have tried it first. I also did not know there was a standard function for searching strings in reverse
I was just using one that I got a few year ago
Thanks for effort you put into the GetSheetNumber function. I will add it to my collection
Kind regards
Stuart Penberthy
Message 4 of 8
stuartmp
Please delete Edited by: stuartmp on Oct 14, 2008 4:55 PM
Message 5 of 8
Mid(oSheet.Name, InStr(1, oSheet.Name, ":") +
1)
Joe ...
Hi
through VBA? Thanks
Message 6 of 8
jR0sal3s
yes...
Public Sub x()
'The sheet number is appended to the sheet name in _
the browser. You can get this name using the Name _
property of the Sheet object and then extract the number from the name. *Brian Ekins
Dim oDoc As DrawingDocument
Set oDoc = ThisApplication.ActiveDocument
Dim NoOfSheets As Integer
Dim CurrentSheet As Integer
NoOfSheets = oDoc.Sheets.Count
Dim strSheetName As String
strSheetName = oDoc.ActiveSheet.Name
If InStr(strSheetName, ":") Then
' Extract the sheet number from the name.
GetSheetNumber = CInt(Right$(strSheetName, Len(strSheetName) - InStrRev(strSheetName, ":")))
Else
'This sheet is not numbered so returnzero.
GetSheetNumber = 0
End If
CurrentSheet = GetSheetNumber
Debug.Print CurrentSheet
Debug.Print NoOfSheets
End Sub
Message 7 of 8
JamieVJohnson2
Isn't the sheet number the same as the document.sheets index value?  If so;
dim sheetNo as integer = 0
For index as Integer = 1 to document.sheets.count
if documents.sheets(index).name = activesheet.name then
'sheet number found it is index.
sheetNo = index
exit for
end if
next
Jamie Johnson : Owner / Sisu Lissom, LLC https://sisulissom.com/
Message 8 of 8
jR0sal3s
i am not quiet sure about that...but the solution posted by Brian Ekins seems to work fine...
