Sheet.name isn't updating - what am I doing wrong?
I am trying rename each of my sheets.  What am I doing wrong?
Sub Main()
    oDrawDoc = ThisApplication.ActiveDocument
    For Each oSheet In oDrawDoc.Sheets
        ModSheetName(oSheet)
    Next
End Sub
Sub ModSheetName(oSheet As Inventor.Sheet)
	Dim SheetName As String = oSheet.Name
	sTemp = InputBox("New Sheet Name", SheetName, SheetName)
'Message box to see that I get the new value i = MessageBox.Show(sTemp, "My iLogic Dialog", MessageBoxButtons.OK, MessageBoxIcon.Hand, MessageBoxDefaultButton.Button1) oSheet.Name = UCase(sTemp)
'Message to to see if the new value was accepted i = MessageBox.Show(oSheet.Name, "My iLogic Dialog", MessageBoxButtons.OK, MessageBoxIcon.Hand, MessageBoxDefaultButton.Button1) oSheet.Parent.Update End Sub
Also, is the update needed?
Thanks in advance.
Mike
clutsa
Have you tried restarting inventor? I literally copy and pasted your code into a rule and it worked just fine. Are you getting an error message?
If I've helped you, please help me by supporting this idea.
Mass Override for Each Model State
Custom Glyph Icon for iMates
philip1009
It does work as posted and it does update the Sheet Names in the Browser, are you trying to update or change something else?
Reboot solved the problem.
Thanks.
