Sheet Metal recognition from Assembly
donaldleigh
donaldleigh
Hi all
I have a rule that is run from the top level assembly that transfers details from a form to all sub-assemblies and parts “Project Details”.
I then have an external rule that is set to trigger on an iProperty Change “Details” in every part and assembly. This rule checks to see if the model is an Assembly, Part, Sheet Metal or Drawing and performs certain things.
The issue I’m having it that when I run the “Project Details” from the top level assembly the “Details” rule in each Sheet metal part is only recognizing it as a part and not a sheet metal part. I think it has to do with the line.
If ThisApplication.ActiveDocument.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" = True Then
When I run the “Details” rule from the Sheet metal part itself it works correct.
How do I change this please?
I have included a sample of the rule and parts. All rules are set up as External rules. This sample transfers the Project iProperty to each part and then each part sets a custom iProperty based n type.
Donald
Inventor 2014
Accepted solutions (3)
chandra.shekar.g
Autodesk Support
Autodesk Support
@donaldleigh,
Hoping that below iLogic code may be helpful.
Dim doc As Document = ThisDoc.Document
ModelType = iProperties.Value("Custom", "Model Type")
If doc.IsModifiable = True Then 'Document can be modified
	If doc.DocumentType = Inventor.DocumentTypeEnum.kDrawingDocumentObject  Then 'Drawing File
		Return
	Else If doc.DocumentType = Inventor.DocumentTypeEnum.kPartDocumentObject  Then 'Part or Sheet Metal File
		If oDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" = True Then 'Sheet Metal File
			ModelType = "Sheet Metal"
		Else 'Part File
			ModelType = "Part"
		End If
	Else If doc.DocumentType = Inventor.DocumentTypeEnum.kAssemblyDocumentObject  Then 'Assembly File
		ModelType = "Assembly"
	End If
Else 'Document can not be modified
End If
'Set Model Type iProperty
If iProperties.Value("Custom", "Model Type") <> ModelType Then
	iProperties.Value("Custom", "Model Type") = ModelType
	iLogicVb.UpdateWhenDone = True
End If
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
MjDeck
@donaldleigh , here is the change that @chandra.shekar.g made:
Original:
If ThisApplication.ActiveDocument.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" = True Then 'Sheet Metal File
Modified:
This uses the document in which the rule is running (which is ThisDoc.Document).
On the other hand, ThisApplication.ActiveDocument is the document that is currently active in the window. The document name will be on the window. In this case, it's the top-level assembly.
Mike Deck
Software Developer
Autodesk, Inc.
donaldleigh
Thanks Guys
I thought it was something in that line not right.
Also as I have
 at the start it should read "doc" not "oDoc"
Again Thanks heaps
Donald
MjDeck
Yes, that's right. Sorry about the typo. We should have tested.
Mike Deck
Software Developer
Autodesk, Inc.
donaldleigh
all good. I'm starting to get a handle on ilogic and spotted it straight away.
at least this tells me i'm doing something right.
Cheers Again
Donald
