Sheet metal flat patterns on same drawing using ilogic?
- Mute
- Permalink
- Report
I've looked through some examples but can't find code which mimics placing the base component as a flat pattern, running the rule from within the drawing.
The example below shows a path to a saved part - I think i need to identify the currently open part.(i don't want to type in the saved location of each part)..take the currently open part, place the flat pattern & close, next..
the next step is to place a second flat part on the same dwg.
Most of the examples I've found create a new drawing - I'd like to keep the one currently open.
Any suggestions welcome.
My current workflow is pretty repetitive, select the part, select flat pattern, select scale (1:1), position & repeat. The result is one dwg with a range of developed sheet metal parts ready for nesting & cutting.
Andrew
