Sheet Metal - Flat Pattern Width and Length - Parametric (VBA) ??
Hi to community.
I need to get sheet metals flat pattern extents width and length expressions in mm format, and assign them to description property of document as parametric values. By this code I can get them in cm unit and can not control precision of values.
Sub AssignFlatPatternDimensionsToDescription(partDoc As PartDocument)
    'If partDoc.DocumentType = kPartDocumentObject Then
        'If IsSheetMetal(partDoc) Then
            On Error GoTo exitSubPartToSheetMetal
            Dim oCompDef As SheetMetalComponentDefinition
            Set oCompDef = partDoc.ComponentDefinition
             If oCompDef.HasFlatPattern = False Then
                 Dim oPartDoc As Document
                 Set oPartDoc = ThisApplication.Documents.Open(partDoc.FullFileName, True)
                 oCompDef.Unfold
                 oPartDoc.Close
             Dim oPropsets As PropertySets
             Set oPropsets = partDoc.PropertySets
             Dim designTrackPropSet As PropertySet
             Set designTrackPropSet = partDoc.PropertySets.item("Design Tracking Properties")
             ' Get the Description property.
             Dim oPropDescription As Property
             Set oPropDescription = oPropsets.item("{32853F0F-3444-11d1-9E93-0060B03C1CA6}").ItemByPropId(kDescriptionDesignTrackingProperties)
             ' Add flat pattern expressions to the property.
             oPropDescription.Expression = "=<Flat Pattern Width> x <Flat Pattern Length>"
        'End If
exitSubPartToSheetMetal:
        If Err.Number <> 0 Then
            Err.Clear
    'End If
End Sub
For a drawing view I can set the label by this code (as parametric) in mm;
'' FLAT PATTERN WIDTH x LENGTH
                    Msg = "<StyleOverride FontSize='0.3'><SheetMetalProperty SheetMetalPropertyID='78850' Precision='1'>FLAT PATTERN EXTENTS WIDTH</SheetMetalProperty></StyleOverride>"
                    Msg = Msg & "<StyleOverride FontSize='0.3'> x </StyleOverride>"
                    Msg = Msg & "<StyleOverride FontSize='0.3'><SheetMetalProperty SheetMetalPropertyID='78849' Precision='1'>FLAT PATTERN EXTENTS LENGTH</SheetMetalProperty></StyleOverride>"
drawView.Label.FormattedText = Msg
And I can expose thickness parameter as property and use the value as parametric in mm. But can't find a way to get flat pattern extents values in mm & and can't control precision..
May someone tell me; if it is possible in VBA; how to do it?
Thanks in advance.
Sergio.D.Suárez
Hi, I usually use an ilogic rule similar to the example below. I use ilogic because it is easier for me to reference this sheet metal document. For example I have an assembly, and I want to create a rule in each metal sheet file linked, this rule I want to be automatically updated before changes in geometry. To achieve this, I use a mother rule that creates other rules in each file of an assembly. I think that vba could also be used to create internal rules for each component, as I described above.
I hope you can solve your problem. regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Hi and thanks for giving time.
I am not so familiar with the logic of iLogic but as I understant iLogic rules execute it self like repainting, or say updating, re-executing the routine. Your code sets a static value, but the rule updates document when a change occurs; if I am not wrong.
In VBA it is not possible as you know. This is exactly the same code as yours and sets the value once - as static.
partDoc.PropertySets.item("Design Tracking Properties").item("Description").Value = strThickness & strLength & "x" & strWidth
partDoc.PropertySets.item("Design Tracking Properties").item("Description").Value = width & "x" & length
When a parameter like thickness or geometry chances, value of item("Description").value remains the same.  It must be a parametric expression.
Thanks a lot.
Sub AssignFlatPatternDimensionsToDescription_II(partDoc As PartDocument)
            oCompDef.Unfold
            oPartDoc.Close
        Dim fpBox As Box
        Set fpBox = oCompDef.FlatPattern.body.RangeBox
        Dim width As Double
        Dim length As Double
        length = fpBox.MaxPoint.X - fpBox.MinPoint.X
        width = fpBox.MaxPoint.Y - fpBox.MinPoint.Y
        Dim objUOM As UnitsOfMeasure
        Set objUOM = partDoc.UnitsOfMeasure
        Dim strLength As String
        Dim strWidth As String
        Dim strThickness As String
        strLength = objUOM.GetStringFromValue(length, UnitsTypeEnum.kDefaultDisplayLengthUnits)
        strWidth = objUOM.GetStringFromValue(width, UnitsTypeEnum.kDefaultDisplayLengthUnits)
        strThickness = objUOM.GetStringFromValue(oCompDef.Thickness.ModelValue, UnitsTypeEnum.kDefaultDisplayLengthUnits)
exitSub:
            Err.Clear
End Sub
Function ExposeSheetMetalThicknessParameterAsProperty(partDoc As PartDocument) As Boolean
    Dim oParameters As Parameters
    Set oParameters = partDoc.ComponentDefinition.Parameters
    On Error Resume Next
    Dim oThicknessParam As Parameter
    Set oThicknessParam = oParameters.item("Thickness")
    If Err.Number = 0 Then
        With oThicknessParam
            .ExposedAsProperty = True
            .CustomPropertyFormat.PropertyType = CustomPropertyTypeEnum.kNumberPropertyType
            .CustomPropertyFormat.Units = UnitsTypeEnum.kMillimeterLengthUnits
            .CustomPropertyFormat.Precision = CustomPropertyPrecisionEnum.kOneDecimalPlacePrecision
            .CustomPropertyFormat.ShowUnitsString = True
        End With
        ExposeSheetMetalThicknessParameterAsProperty = True
        Exit Function
    ExposeSheetMetalThicknessParameterAsProperty = False
End Function
' Add an expression to the property.
       partDoc.PropertySets.item("Design Tracking Properties").item("Description").Expression = "=<Thickness> - <Sheet Metal Width> x <Sheet Metal Length>"
       'partDoc.PropertySets.item("Design Tracking Properties").item("Description").Expression = "=<Flat Pattern Width> x <Flat Pattern Length>"
Works as parametric.. in VBA. The only problem is precision.
partDoc.UnitsOfMeasure.LengthDisplayPrecision = 1
This solves the precision issue..
YuhanZhang
Glad to see you solved it. Here is reference for those who want to know why:
http://help.autodesk.com/view/INVNTOR/2020/ENU/?guid=GUID-9ED64200-A0CA-4F27-A308-9BF7ADB22D06
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
Thank you for informative article.
And we can control the precision of decimal values from;
Tools Ribbon > Options Panel > Document Settings > Units Tab > Linear Dim Display Precision value.
And also selecting the option Display precise value is aiding while sketch editing when you set 0. in Linear Dim Display Precision value. Creating a template file using these presettings will help me so much.
Thanks a lot.
