How to get full filename of selected Occurence
SandmanINV
SandmanINV
Like my title topic, I want get full filename (path file) of selected Occurence and display in a label or textbox. But i dont know how to do that.
Someone help me pls.
Thank you
Sergio.D.Suárez
Hi, I guess you're talking about ilogic. I'll give you a couple of examples.
With this example you can select a component and observe the fullfilename and the displayname
Dim oPart As ComponentOccurrence
oPart = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyLeafOccurrenceFilter, "Select component")
If oPart Is Nothing Then
	Exit Sub
Else
	Dim odoc As Document
	odoc = oPart.Definition.Document
	MessageBox.Show(odoc.DisplayName, "Document Name")
	MessageBox.Show(odoc.FullFileName, "FullFileName")
 If you need the path of the selected file you could use something like this
	Exit Sub
Else
	Dim CurFileName As String
	'get the path and file name of the selected item
	CurFileName = odoc.FullFileName
	'defines backslash as the subdirectory separator
	Dim strCharSep As String = System.IO.Path.DirectorySeparatorChar
	'find the postion of the last backslash in the path
	FNamePos = InStrRev(CurFileName, "\", -1)
	'get the file name with the file extension
	Name = Right(CurFileName, Len(CurFileName) - FNamePos)
	'get the path of the folder containing the file
	Folder_Location = Left(CurFileName, Len(CurFileName) - Len(Name)-1)
	MessageBox.Show(Folder_Location, "Folder Location")
If you have previously selected the assembly occurrence, I think you could use something like this.
Dim oSSet As SelectSet = ThisDoc.Document.SelectSet
If oSSet.Count = 0 Then
	Exit Sub
Else
	Dim oCC As ComponentOccurrence = TryCast(oSSet.Item(1), ComponentOccurrence)
	Dim oDoc As Document
	oDoc = oCC.Definition.Document
	MessageBox.Show(oDoc.FullFileName, "FullFileName")
 similarly if you have previously selected the component in the assembly and you need your path, I think you should try something like this.
	Exit Sub
Else
	CurFileName = oDoc.FullFileName
 I hope that whatever path you try to take helps you solve your problem. regards!
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
SandmanINV
I am using Vb.net. But your reply is so good example with me. Thank you, thank very much.
