Hi, In Flat Pattern there is no Direct Edit command
Is it possible to offset selected single face ( or faces along an axis ) to offset normal to face through the solid side / towards the full side of the body via API?
I may create a sketch and then create a cut feature, but there are hundreds of features that I need to arrange. I want to code something practical.
For example I need to set the gap to 5 mm, so for each side I need to offset faces 0,5 mm; but this feature will only present at flat pattern layout of sheet metal. Please answer if it is possible or not.. and may be you may guide me 🙂 Thanks
