Sheet Metal, Flat Pattern, Direct Edit - Move / Offset Faces
hrnkilicU6XUZ
hrnkilicU6XUZ
Hi, In Flat Pattern there is no Direct Edit command
Is it possible to offset selected single face ( or faces along an axis )  to offset normal to face through the solid side / towards the full side of the body via API?
I may create a sketch and then create a cut feature, but there are hundreds of features that I need to arrange. I want to code something practical.
For example I need to set the gap to 5 mm, so for each side I need to offset faces  0,5 mm; but this feature will only present at flat pattern layout of sheet metal. Please answer if it is possible or not.. and may be you may guide me  🙂 Thanks
lah29-bertrand
Use the model state.
one for the cut and an other for the finish product.
Create the"cut Model State" and change the cotation or add feature as you need
Make the flat pattern with this model state activ.
I think you can automate this with ilogic in the fold part
(Add model state, change the dimension, unfold, generate a DXF,...)
navya_gelli
Hello, @hrnkilicU6XUZ ,
Just checking in—did the responses shared by @lah29-bertrand help clarify your question?
If so, please consider clicking the "Accept Solution" button. Doing so helps others in the community find answers to similar issues.
If your question still needs more attention, feel free to reply here with an update. This way, other members can jump in with further suggestions or guidance to help you move forward.
All the best,
Navya | Community Manager
