Sheet metal flat pattern defer update
mikejones
mikejones
I'm trying to export a sheet metal flat pattern from a drawing the sheet metal drawing file. What I have so far works ok as long as the defer update if set on the flat pattern. How do I switch the defer update to off in iLogic? I've found the FlatPatternSettings.DeferUpdate property but I am unsure of how to use it. Any help appreciated.
Mike
Autodesk Certified Professional
Michael.Navara
Here is the sample
Dim part As PartDocument = ThisDoc.Document
part.FlatPatternSettings.DeferUpdate = False
mikejones
I tried that but it didn't work so I changed the ThisDoc.Document to ThisApplication.ActiveDocument and that did the trick.
Thand for the fast reply.
Mike
