Sharing a movable model without allowing them to see details
Is there any way possible to share an Inventor model to that the recipient can still move the overall thing around but can not take it apart to see the interior. An example would be allowing someone to play with a model of a jack in the box and seeing that it will pop up but not allowing them to take apart the box and see the inner workings.
If this is possible please let me know how.
AlexFielder
Shrinkwrap is the command you're looking for- it'll let you hide the details in any sub-assembly, but you'll need to make sure (in the parent assembly) that you don't constrain to any geometry (internals holes etc.) that are likely to be removed by the toolset.
