setting up API in Visual Basic using C#
cstephens58F4Q
cstephens58F4Q
I have previously had a multiple successful Add-ins created using VB.net. I was told I need to start writing them in C# so our IT department can better assist. The build is successful, it opens inventor, shows in the Add-in manager, however it won't populate the button in any ribbon. I have all functions called out same as in the VB.net Add-ins just translated to C# language. Below is the full 'StandardAddInServer.cs" file any assistance would be greatly appreciated.
using Inventor;
using Microsoft.Win32;
using System;
using System.Collections.Generic;
using System.Drawing;
using System.Runtime.InteropServices;
namespace Furnace
    /// <summary>
    /// This is the primary AddIn Server class that implements the ApplicationAddInServer interface
    /// that all Inventor AddIns are required to implement. The communication between Inventor and
    /// the AddIn is via the methods on this interface.
    /// </summary>
    [GuidAttribute("431205c6-c088-422e-82de-9bf8b0801f0c")]
    public class StandardAddInServer : Inventor.ApplicationAddInServer
        // Inventor application object.
        private Inventor.Application m_inventorApplication;
        private UserInterfaceEvents m_uiEvents;
        private Inventor.ButtonDefinition buttonDefinition;
        private object AddClientID;
        public StandardAddInServer()
        #region ApplicationAddInServer Members
        public void Activate(Inventor.ApplicationAddInSite addInSiteObject, bool firstTime)
            // This method is called by Inventor when it loads the addin.
            // The AddInSiteObject provides access to the Inventor Application object.
            // The FirstTime flag indicates if the addin is loaded for the first time.
            // Initialize AddIn members.
            m_inventorApplication = addInSiteObject.Application;
            m_uiEvents = m_inventorApplication.UserInterfaceManager.UserInterfaceEvents;
            ControlDefinitions controlDefs = m_inventorApplication.CommandManager.ControlDefinitions;
            //IPictureDisp smallimage =
            var commandManager = m_inventorApplication.CommandManager;
            buttonDefinition = commandManager.ControlDefinitions.AddButtonDefinition("Furnace Automation", "Automation", CommandTypesEnum.kQueryOnlyCmdType, AddClientID);
            // Connect to the user-interface events to handle a ribbon reset.
            buttonDefinition.OnExecute += ButtonDefinition_OnExecute;
            buttonDefinition.AutoAddToGUI();
            if (firstTime)
                AddToUserInterface();
        private void ButtonDefinition_OnExecute(NameValueMap Context)
            throw new NotImplementedException();
        public void Deactivate()
            // This method is called by Inventor when the AddIn is unloaded.
            // The AddIn will be unloaded either manually by the user or
            // when the Inventor session is terminated
            // TODO: Add ApplicationAddInServer.Deactivate implementation
            // Release objects.
            m_inventorApplication = null;
            m_uiEvents = null;
            buttonDefinition = null;
            buttonDefinition.OnExecute -= ButtonDefinition_OnExecute;
            GC.Collect();
            GC.WaitForPendingFinalizers();
        public object Automation
            // This property is provided to allow the AddIn to expose an API
            // of its own to other programs. Typically, this  would be done by
            // implementing the AddIn's API interface in a class and returning
            // that class object through this property.
            get
                // TODO: Add ApplicationAddInServer.Automation getter implementation
                return null;
        #endregion
        #region User interface definition
        private void AddToUserInterface()
            Ribbon ZeroLoc = m_inventorApplication.UserInterfaceManager.Ribbons["ZeroDoc"];
            RibbonTab ToolLoc = ZeroLoc.RibbonTabs["id_TabTools"];
            string ClientID = null;
            RibbonPanel FinalLoc = ToolLoc.RibbonPanels.Add("Furnace Automation", "Automation2", ClientID);
            FinalLoc.CommandControls.AddButton(buttonDefinition);
        public void ExecuteCommand(int CommandID)
        #endregion
Michael.Navara
Avoid to use ClientId = null. Here is modified version
using Inventor;
using System;
namespace Furnace
    /// <summary>
    /// </summary>
    [GuidAttribute("3d2d5718-2cc0-4563-8275-cb8d02ab983a")]
    public class StandardAddInServer : ApplicationAddInServer
        private /*object*/ const string AddClientID = "{3d2d5718-2cc0-4563-8275-cb8d02ab983a}";
        private ButtonDefinition buttonDefinition;
        private Application m_inventorApplication;
        public void Activate(ApplicationAddInSite addInSiteObject, bool firstTime)
            var controlDefs = m_inventorApplication.CommandManager.ControlDefinitions;
                "Automation",
                AddClientID);
            if (firstTime) AddToUserInterface();
            // Release objects.
            m_uiEvents = null;
            GC.Collect();
        public object Automation =>
            null;
        #endregion
            var ZeroLoc = m_inventorApplication.UserInterfaceManager.Ribbons["ZeroDoc"];
            var ToolLoc = ZeroLoc.RibbonTabs["id_TabTools"];
            string ClientID = AddClientID;
            var FinalLoc = ToolLoc.RibbonPanels.Add("Furnace Automation", "Automation2", ClientID);
        #endregion
cstephens58F4Q
I figured out the issue was I was calling an old .dll file so all the changes I had done were not being updated in the active file in Inventor.
cstephens58F4Q
Thanks for the pointer on that item. I am learning C# on the fly currently with this change.
