Create Dedicated View Representation
LIUZHILI8888
Message 1 of 9
LIUZHILI8888
how to Create Dedicated View Representation to create a view that displays only the flattened surface. The view representation is useful to isolate the surface in a part file
Replies (8)
Message 2 of 9
LIUZHILI8888
Message 3 of 9
A.Acheson
Hi @LIUZHILI8888
Can you share an image of this done manually first then we might be able to assist with a code version of the same.
Regards
Alan
Message 4 of 9
LIUZHILI8888
Message 5 of 9
A.Acheson
Hi @LIUZHILI8888
You can follow the path from part document down to DesignViewRepresentations. API help here
Dim partDoc As PartDocument = ThisDoc.Document
Dim partDef As PartComponentDefinition = partDoc.ComponentDefinition
Dim repManager As RepresentationsManager = partDef.RepresentationsManager
Dim designViewReps As DesignViewRepresentations = repManager.DesignViewRepresentations
designViewReps.add("NewViewRep")
Regards
Alan
Message 6 of 9
LIUZHILI8888
how to  isolate the surface in a part file tn the view representation
Message 7 of 9
LIUZHILI8888
Message 8 of 9
A.Acheson
Hi @LIUZHILI8888
I think you will need to show the manual approach you take to isolate the surface in the model before you can do it by code. You cannot hide features unless they have been made into an independent solid and then you can control visibility of these solids.
Regards
Alan
Message 9 of 9
Frederick_Law
I don't think View Rep work for this.
More like ModelState.
SheetMetal has Flat Pattern.
