Setting thumbnail image via ilogic
I am trying to write some iLogic that process' a library directory and sets the thumbnail to a custom image. I have searched the web and have only found VBA (32 bit) answers. When I tried to use the converted VBA code from https://modthemachine.typepad.com/my_weblog/2010/06/accessing-thumbnail-images.html.
Sub WriteThumbnail(ByVal FileName As String) ' Get the Summary Information property set. ' Get the thumbnail property. When using VBA, this will 'dsPSet is = "Inventor Summary Information" Dim thumbProp As Inventor.Property thumbProp = dsPSet.Item("Thumbnail") ' Get the thumbnail image. Dim thumbnail As stdole.IPictureDisp thumbnail = thumbProp.Value ' Check that an image was returned. It's possible for a ' file to not have a thumbnail. If Not thumbnail Is Nothing Then ' Write the thumbnail to disk. SavePicture(thumbnail, FileName) End If End Sub
I get a 'SavePicture' is not declared. It may be inaccessible due to its protection level.". I have stdole referenced and Imported. Any help would be appreciated.
Thanks.
