Dimension Placement
Dimension Placement
Formsprag
Dimension Placement
Formsprag
I have this code that works great for placing dimensions in a view now I would like to trigger the placement based off of a certain work point being present in the view. The work points will be one of the following:
WP_S_MP
WP_M_MP
WP_L_MP
WP_LM_MP
The rules the would need to run is as follows:
If WP_S_MP Then
	Dim HorizontalLengthPos1 = ThisDrawing.Geometry.Point2d(0, 0)
	HorizontalLengthPos1.InDatabaseUnits = WP_S_MP.PointOnSheet
	HorizontalLengthPos1.Y = HorizontalLengthPos1.Y - 1.5 * FRONT_VIEW.Scale
	Dim HorizontalLengthPos2 = ThisDrawing.Geometry.Point2d(0, 0)
	HorizontalLengthPos2.InDatabaseUnits = WP_S_MP.PointOnSheet
	HorizontalLengthPos2.Y = HorizontalLengthPos2.Y - 3 * FRONT_VIEW.Scale
If WP_M_MP Then
	Dim HorizontalLengthPos3 = ThisDrawing.Geometry.Point2d(0, 0)
	HorizontalLengthPos3.InDatabaseUnits = WP_M_MP.PointOnSheet
	HorizontalLengthPos3.Y = HorizontalLengthPos3.Y - 1.5 * FRONT_VIEW.Scale
	Dim HorizontalLengthPos4 = ThisDrawing.Geometry.Point2d(0, 0)
	HorizontalLengthPos4.InDatabaseUnits = WP_M_MP.PointOnSheet
	HorizontalLengthPos4.Y = HorizontalLengthPos4.Y - 3 * FRONT_VIEW.Scale
If WP_L_MP Then
	Dim HorizontalLengthPos5 = ThisDrawing.Geometry.Point2d(0, 0)
	HorizontalLengthPos5.InDatabaseUnits = WP_L_MP.PointOnSheet
	HorizontalLengthPos5.Y = HorizontalLengthPos5.Y - 1.5 * FRONT_VIEW.Scale
	Dim HorizontalLengthPos6 = ThisDrawing.Geometry.Point2d(0, 0)
	HorizontalLengthPos6.InDatabaseUnits = WP_L_MP.PointOnSheet
	HorizontalLengthPos6.Y = HorizontalLengthPos6.Y - 3 * FRONT_VIEW.Scale
If WP_LM_MP Then
	Dim HorizontalLengthPos7 = ThisDrawing.Geometry.Point2d(0, 0)
	HorizontalLengthPos7.InDatabaseUnits = WP_LM_MP.PointOnSheet
	HorizontalLengthPos7.Y = HorizontalLengthPos7.Y - 1.5 * FRONT_VIEW.Scale
	Dim HorizontalLengthPos8 = ThisDrawing.Geometry.Point2d(0, 0)
	HorizontalLengthPos8.InDatabaseUnits = WP_LM_MP.PointOnSheet
	HorizontalLengthPos8.Y = HorizontalLengthPos8.Y - 3 * FRONT_VIEW.Scale
Help Please!
I think this should work for you
For Each oPoint As WorkPoint In ThisDoc.Document.ComponentDefinition.WorkPoints
	Select Case oPoint.Name
	Case "WP_S_MP"
	Case "WP_M_MP"
	Case "WP_L_MP"
	Case "WP_LM_MP"
	End Select
Next
Formsprag
That worked for that section but now I'm getting this error:
I assume from your other post it's coming from the bottom section of your code where you add the dimensions. You need to include those in your Select otherwise it will try to create dimensions for every type. Also you don't need to define a line for each one unless you plan to do more with them later.
Dim genDims = Sheet_1.DrawingDimensions.GeneralDimensions
	Case "WP_S_MP"
		genDims.AddLinear("Dimension 1", HorizontalLengthPos, WP_S_F1_OE, WP_S_F1_IE)
		genDims.AddLinear("Dimension 2", HorizontalLengthPos, WP_S_F2_OE,WP_S_F2_IE)
		genDims.AddLinear("Dimension 3", HorizontalLengthPos2, WP_S_MP, WP_S_FLH, DimensionTypeEnum.kHorizontalDimensionType)
		genDims.AddLinear("Dimension 4", HorizontalLengthPos2, WP_S_MP, WP_GV_RH, DimensionTypeEnum.kHorizontalDimensionType)
		genDims.AddLinear("Dimension 5", VerticalLengthPos, WP_S_F2_OE, WP_S_FVCP, DimensionTypeEnum.kVerticalDimensionType)
		genDims.AddLinear("Dimension 6", VerticalLengthPos2, WP_S_F2_OE, F_B_TF, DimensionTypeEnum.kVerticalDimensionType)
	Case "WP_M_MP"
	Case "WP_L_MP"
	Case "WP_LM_MP"
	End Select
Next
Formsprag
The dimensions may move from left to right, top to bottom of the view depending on how the user defines the form variables. That's why I'm listing them more than once. The only problem I'm having is with the following line:
It gives this error:
I'm not that familiar with working with drawings but try replacing
with
For Each oPoint As WorkPoint In ThisDoc.ModelDocument.ComponentDefinition.WorkPoints
 This will get the document of the first view in the drawing, but I don't know if you have multiple assemblies in your drawing
Formsprag
Perfect, no errors!
Thank you for all your help!
