Set the row of an iAssembly within the parent assembly
meck
meck
Hi All,
I have a main assembly filled with iAssembly sub-assemblies. I would like to be able to set the active row of the sub-assemblies from within the main assembly using iLogic. The reason for this is that there are millions of possible combinations available. I wish to create a GUI to make it easy for the user to select the various combination.
So can someone please enlighten me as to how I can get to the sub-assemblies' table row so I can set the active row.
Thanks in advance!
Mike Eck
Master Drafter/ CAD Programmer
Using Inventor 2018
HermJan.Otterman
create a new iLogic rule,
look in the snippets under iPart
there are some snippeets you could use like "change row"...
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
chandra.shekar.g
Autodesk Support
Autodesk Support
@meck,
You can also refer to below help documentation link on ChangeRow function.
http://help.autodesk.com/view/INVNTOR/2019/ENU/?guid=__files_GUID_020555BE_6197_4D27_8B31_A4D62E2CC2...
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
