Dynamic Slider values - iLogic forms - IV2017
Scott_Stubbington
Scott_Stubbington
Background - You have controls that are put onto iLogic forms and by default Parameters are Textboxes but with a tweak they can become a Slider, the default values of the Slider are... Minimum 1, Maximum 10, and Step Size 1.
I would like to be able to manipulate the values of the Slider at runtime to ensure no bad entries, can this be done?  If it can, how?
Thanks in advance
Scott Smiley Happy
CCarreiras
HI!
You can expand the Slider properties and set the diferent minimum and maximum value, step size also.
CCarreiras
Scott_Stubbington
I would consider changing the values that way to be Design time, not Run Time, I want to be able to evaluate what we currently have and modify these values when the user Runs the rule.
