Set Precision in iLogic
GKPByDesign
GKPByDesign
I have a code below,
however the ending iProperties need to be set to precision 0, and no units, leading or trailing zeros, however I believe I may need to interject a custom parameters first, and let the iProp equal these.
Let
Run code to get L W T
L= Custom Para L
W= Custom Para W
T= Custom Para T
Set Precision on Custom Para L W T
Custom iProp Length = Custom Para L
Custom iProp Width = Custom Para W
Custom iProp Thickness = Custom Para T
Imports system.Collections
Public Sub Main()
    ' Get the active assembly.
    Dim oAsmDoc As AssemblyDocument
    oAsmDoc = ThisApplication.ActiveDocument
    ' Get the assembly component definition.
    Dim oAsmDef As AssemblyComponentDefinition
    oAsmDef = oAsmDoc.ComponentDefinition
    ' Get all of the leaf occurrences of the assembly.
    Dim oLeafOccs As ComponentOccurrencesEnumerator
    oLeafOccs = oAsmDef.Occurrences.AllLeafOccurrences
    ' Iterate through all part occurrences in assembly.
    Dim oOcc As ComponentOccurrence
    For Each oOcc In oLeafOccs
		L = Math.Abs(oOcc.RangeBox.MaxPoint.X - oOcc.RangeBox.MinPoint.X) * 10
		W = Math.Abs(oOcc.RangeBox.MaxPoint.Y - oOcc.RangeBox.MinPoint.Y) * 10
		H = Math.Abs(oOcc.RangeBox.MaxPoint.Z - oOcc.RangeBox.MinPoint.Z) * 10
		Dim oList As New ArrayList
		oList.Add(L)
		oList.Add(W)
		oList.Add(H)
		Call oList.Sort()
		iProperties.Value(oOcc.Name,"Custom", "Length") =  oList.Item(2)& " mm"
		iProperties.Value(oOcc.Name,"Custom", "Width") = oList.Item(1)& " mm"
		iProperties.Value(oOcc.Name, "Custom", "Thickness") = oList.Item(0) & " mm"
		  Next
End Sub
GKPByDesign
I have found the code that code be used, but have no ideas how to implement
DimoPartDocAsPartDocument
 oPartDoc=ThisApplication.ActiveDocument
 DimoParameterAsParameter
 DimoFormatAsCustomPropertyFormat
 ForEachoParameterInoPartDoc.ComponentDefinition.Parameters.UserParameters
 oFormat=oParameter.CustomPropertyFormat
 oParameter.ExposedAsProperty=True
 oFormat.PropertyType=Inventor.CustomPropertyTypeEnum.kTextPropertyType
 oFormat.Precision=Inventor.CustomPropertyPrecisionEnum.kZeroDecimalPlacesPrecision
 oFormat.Units="mm"
 oFormat.ShowUnitsString= False
 oFormat.ShowLeadingZeros= False
 oFormat.ShowTrailingZeros=False
NextoParameter
Sergio.D.Suárez
		iProperties.Value(oOcc.Name,"Custom", "Length") =  Round(oList.Item(2),0)& " mm"
		iProperties.Value(oOcc.Name,"Custom", "Width") = Round(oList.Item(1),0)& " mm"
		iProperties.Value(oOcc.Name, "Custom", "Thickness") = Round(oList.Item(0),1) & " mm"
Hi, try changing the last lines.
I hope this helps. regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
GKPByDesign
Any body wants a cutting list that you can run from a component file created from a multi body part, code below! You can also create a cutting list from it too!
Public Sub Main()
		oList.Add(L)
		oList.Add(W)
		oList.Add(H)
		Call oList.Sort()
		  Next
End Sub
