Set Multivalue Parameter from values Message box outputs
bronc3buster842001
Message 1 of 23
bronc3buster842001
This rule retrieves the info I want from the excel sheet. How do I take the values from the message box and make it into a multivalue parameter.
GoExcel.Open("C:\Users\Brian\Desktop\Book1.xlsx", "Sheet1")
For rowNumber = 5 To 37
	If Voltage = 6.3 Then
		If Not GoExcel.CellValue("B" & rowNumber) = "" Then
			MessageBox.Show(GoExcel.CellValue("A" & rowNumber))
Next
GoExcel.Close
Replies (22)
Message 21 of 23
bronc3buster842001
What version of inventor are you using and Ill redo it so you can open the file
Message 22 of 23
A.Acheson
I think you have an issue because you are setting the list and trying to change the parameter at the same time. I would suggest having one rule to create the value list  and one to set them. Or check the workflow your using manually and try and replicate this. A video would be more helpful if you can't figure it out, this will help see where the workflow is falling down.
Regards
Alan
Message 23 of 23
bronc3buster842001
Ok I serperated the rules and I think its working right now.
