Set Multivalue Parameter from values Message box outputs
bronc3buster842001
Message 1 of 23
bronc3buster842001
This rule retrieves the info I want from the excel sheet. How do I take the values from the message box and make it into a multivalue parameter.
GoExcel.Open("C:\Users\Brian\Desktop\Book1.xlsx", "Sheet1")
For rowNumber = 5 To 37
	If Voltage = 6.3 Then
		If Not GoExcel.CellValue("B" & rowNumber) = "" Then
			MessageBox.Show(GoExcel.CellValue("A" & rowNumber))
Next
GoExcel.Close
Replies (22)
Message 2 of 23
A.Acheson
A few steps
Additions manually:
  1. Create a parameter with the correct units your working with.
Additions By Code:
  1. Create list of either, string, double or Integer depending on what data type your working with.
  2. Add to the list
  3. Make the multivalue parameter = to the list.
Dim List as New List ( Of String)
        List.Add(GoExcel.CellValue("A" & rowNumber))
Next
GoExcel.Close
MultiValue.List(“ParamName”)​ = List
If you have any questions feel free to ask. The Ilogic help is here which will give you more information.
Regards
Alan
Message 3 of 23
bronc3buster842001
Thats works. I was close to having it right.
Message 4 of 23
bronc3buster842001
Is there a way to also set the default index for the list. The normal options I cant get to work
Message 5 of 23
A.Acheson
Could you give an example? Have you tried the built in snippet? In my testing I could not get this to function.
MultiValue.SetValueOptions(True, DefaultIndex := 0)
Regards
Alan
Message 6 of 23
bronc3buster842001
I wasnt able to get that to work either
Also found this bit of code I tried
MultiValue.SetValueOptions(True, DefaultIndex := 2)
MultiValue.SetList("T3", "60", "65", "70", "75", "80", "85", "90", “95”, "100")
MultiValue.SetList("T4", 60, 65, 70, 75, 80, 85, 90, 95, 100)
Dim oParam1 As UserParameter
oParam1 = ThisDoc.Document.componentdefinition.parameters.item("T3")
oParam1.ExpressionList.SetExpressionList(oParam1.ExpressionList.GetExpressionList(), True, 8)
Dim oParam2 As UserParameter
oParam2 = ThisDoc.Document.componentdefinition.parameters.item("T4")
oParam2.ExpressionList.SetExpressionList(oParam2.ExpressionList.GetExpressionList(), True, 4)
Message 7 of 23
A.Acheson
The expression list method via the API works. The ilogic version only works on a string value and only sometimes for me. Here is the explanation. Maybe someone can indicate why it doesn't work. Perhaps it needs very specific criteria.
Forces the parameter to have a value which is in its multi-value list. If you then change the multi-value list, it also sets the current value of the parameter to one of the values in the list. This function does not change the value if it is found in the new list.
DefaultIndex := 0
This applies only to Text parameters. If the current parameter value is not in the new list, the parameter is set to the first value (Index 0) in the list. You can choose a value other than 0. This has no effect on numeric parameters. For numeric parameters, the value chosen from the list will be the one that is closest to the current value.
Regards
Alan
Message 8 of 23
bronc3buster842001
I wasnt able to get the expression list method via the API to work.
Message 9 of 23
A.Acheson
This is all you need to set the I dex of the parameter.
If this doesn't work just post up a screenshot of the more info if an error exist.
Regards
Alan
Message 10 of 23
bronc3buster842001
If works but doesnt allow me to select any other value from the list
Message 11 of 23
A.Acheson
That code will only select which one you want default at a moment in time like when adding a new parameter etc it isnt a user interface for the parameter. If you want the user to select and set the parameter by code you can use an inputlist box or use the built in parameter box or put the parameter in a form.
Dim value as Integer = InputListBox("Prompt",MultiValue.List("T5"), defaultEntry, Title := "Dialog Title", ListPrompt := "List Prompt")
T5 = value
MessageBox.Show(T5)
Regards
Alan
Message 12 of 23
bronc3buster842001
I attached a part file in my last post. I have the 2 parameters I want the user to select in a form.
Message 13 of 23
A.Acheson
I don't have 2022 so can't open the file. Here is the instructions . No code needed to manually set up the form. Use a global form if you want the form  for multiple files.
Regards
Alan
Message 14 of 23
bronc3buster842001
That is what I have.
Message 15 of 23
bronc3buster842001
This gives me an error
Dim List As New ArrayList
GoExcel.Open("E:\Inventor\Electronic Parts\Capacitors\_Configs\Aluminum Electrolytic Capacitor.xlsx", "Sheet1")
Select Case Voltage
	Case = 6.3
				List.Add(GoExcel.CellValue("A" & rowNumber) & "uF")
			MultiValue.List(“Cap”) ​= List
			If Cap = GoExcel.CellValue("A" & rowNumber) & "uF" Then
				DiaLen = GoExcel.CellValue("B" & rowNumber)
Message 16 of 23
A.Acheson
I am not certain of your design intent but you can get more information about the error with the more info tab
If you use the parameter function you will find that the parameters update while the rule runs. It may help how the rule functions.
Parameter.UpdateAfterChange = True
Select Case Voltage
	Case = 6.3
			MultiValue.List("Cap") ​= List
			If Parameter("Cap") = GoExcel.CellValue("A" & rowNumber) & "uF" Then
				Parameter("DiaLen") = GoExcel.CellValue("B" & rowNumber)
		Next
End Select
Regards
Alan
Message 17 of 23
bronc3buster842001
This is from more info on the error
System.ArgumentException: The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at Inventor.ExpressionList.SetExpressionList(String[]& ExpressionList, Boolean ChangeCurrentValue, Int32 CurrentValueIndex)
at iLogic.CadExpressionList.SetExpressionList(Parameter param, IList valueList, Boolean changeExpression, Int32 defaultIndex)
at iLogic.MultiValueParam.SetListToParam(Parameter param, IList vList)
at ThisRule.Main() in rule: Test_Copy_Copy, in document Part1.ipt:line 17
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Message 18 of 23
bronc3buster842001
Here is my form. Basically when you select a voltage it populates the cap values. But I would like it to set a default value.
Message 19 of 23
A.Acheson
Ok I think I get your intent now. When you populate the blank parameter "Cap" no initial value is being set.
So to do this after the parameter receives the list to form the multivalue parameter, use Method 1/2 in the below. In short you are just setting the parameter equal to a value in the list.
GoExcel.Open("C:\Users\aacheson\Desktop\WFH\Samples\VoltageTest.xlsx", "Sheet1")
Select Case Voltage
	Case = 6.3
			If Not GoExcel.CellValue("B" & rowNumber) = Nothing Then
		Next
		'Method 1 Set Default by index of parameter starting from 0
		Dim oParam1 As UserParameter = ThisDoc.Document.componentdefinition.parameters.item("Cap")
		oParam1.ExpressionList.SetExpressionList(oParam1.ExpressionList.GetExpressionList(), True, 3)'0,1,2,3
		MessageBox.Show(oParam1.Value, "Title")
		'Method 2 Set Default by Setting the parameter =  a value
		Parameter("Cap") = GoExcel.CellValue("A" & 8) & "uF"
		MessageBox.Show(Parameter("Cap"), "Title")
End Select
 This line will not work as it is designed to work when the list changes but it cannot be used at the beginning because there is no list to change. It is only being created. It cannot be used after each value is added because if you had a index of 8 and only 7 values added it will error out.  So it must be placed after the list is complete.
 Here is a reworked example and how to use the built in Index setting. There was too many operations happening in the original for loop to make it work.
Dim FileName As String = "E:\Inventor\Electronic Parts\Capacitors\_Configs\Aluminum Electrolytic Capacitor.xlsx"
GoExcel.Open(FileName, "Sheet1")
Select Case Voltage
	Case = 6.3
		Next
		'Set List and Intitial value
		MultiValue.SetValueOptions(True, DefaultIndex := 1)
		Parameter("Cap") = "0uF" ' Add a value not in the list to ensure the list changes when initialized this will trigger the Set Value Options line to work
		'[Match The DiaLen Parameter To Cap Parameter
		Dim CapExcel As String = Left(Parameter("Cap"), (Len(Parameter("Cap")) -2))'Because excel value is not matching parameter, we need to convert to excel value
		'MessageBox.Show(CapExcel, "Parameter to CapExcel Conversion")
		GoExcel.TitleRow = 1
		i = GoExcel.FindRow(FileName, "Sheet1", "Cap", "=", CapExcel)
		If i = -1 Then MessageBox.Show("No value found or blank cell found! Exiting", "iLogic Find Row Warning") : Return ' Ensure no blank cells Or find row will Return -1 Or Error message cannot find Object.
		Parameter("DiaLen") = GoExcel.CurrentRowValue("DiaLen")
End Select
Regards
Alan
Message 20 of 23
bronc3buster842001
I can get it to set the default value. It just doesnt allow me to change it it the list
