Set item digit as last word/digit as part number.
jesserop
jesserop
Hi all,
Is there a vba macro available that sets the last part of a partname as the itemnr in the bomlist?
It only has to change the item in the bomlist in 2D drawing, nothing to the part his bomstatus itself.
dalton98
Heres rough example that worked for me. If all of your part numbers have the same format then you could look into formatting strings. Might be cleaner working with it that way.
On Error Resume Next
Dim oDDoc As DrawingDocument = ThisDoc.Document
Dim oPartsList As PartsList = oDDoc.ActiveSheet.PartsLists(1)
Dim partnumber As String = "12141-1123-95-MASTER"
For Each oRow As PartsListRow In oPartsList.PartsListRows
	Dim ItemDigit() As String = oRow.Item(3).Value.Split("-")
	oRow.Item(1).Value = ItemDigit(ItemDigit.Count - 2) & "-" & ItemDigit(ItemDigit.Count - 1)
	oRow.Item(3).Value = oRow.Item(3).Value.Split(ItemDigit(ItemDigit.Count - 2) & "-" & ItemDigit(ItemDigit.Count - 1))(0)
Next
jesserop
Thanks a lot! One little question.
The part number in the partslist has an override now, so it doesn't update with changes.
Is there any way to leave the part number by default?
dalton98
You can just comment out the line that changes the row for the part number if you don't want it to change. Or making sure the cell value isnt static:
oRow.Item(3).Static = False
