PROBLEMS WITH A CONSTRAINT BETWEEN WORK PLANES
Luis_Pacheco_3D
Luis_Pacheco_3D
I Wrote this code to create a Plane and constrained it with a Work Plane in a Part. This works until the last line of the code where it throws me an error.
	oPart  = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyLeafOccurrenceFilter, "Select a Part")
	oPlane1 = oPart.Definition.WorkPlanes.Item("UCS_TOP: XY Plane")
	MessageBox.Show(oPlane1.name, "Title")
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
Dim oTG As TransientGeometry
oTG = ThisApplication.TransientGeometry
Try
		oAsmCompDef.WorkPlanes.Item("Plano_2").Delete
Catch
	'Do nothing
End Try
oPlane2 = oAsmCompDef.WorkPlanes.AddFixed(oTG.CreatePoint(0,0,0),oTG.CreateUnitVector(0,0,1),oTG.CreateUnitVector(0,1,0),False)
oPlane2.Name = "Plano_2"
MessageBox.Show(oPart.name , "Title")
'Constraints.AddMate("Mate:20", "", oPlane2.Name, "SKELETON_SC_JM_02:1" , "UCS_TOP: XY Plane")
Constraints.AddMate("Mate:20", "", oPlane2.Name, oPart.name, "UCS_TOP: XY Plane")
If I activate the line 23, the rule works correctly, but if I activate the line 24 ( deactivating the line 23). The code does everything except the constraint, showing the following error
Error in rule: Rule3, in document: SC_JM_02.iam
Unable to cast object of type 'System.String' to type 'Autodesk.iLogic.Types.ComponentArgument'.
How can I fix it?
A.Acheson
There seems to be too many arguments in your ilogic function and they are of the wrong type.
Try this
Edit, I missed the component referencing. See forum post here
Constraints.AddMate("", "oPart.Name", "oPlane1.Name", "", "oPlane2.Name",
                    0 mm)
Another method to do this is us going the API directly. It will use the object directly rather than by name.
   oAsmCompDef.Constraints.AddMateConstraint(oPlane1, oPlane2, 0)
 The API sample is shown here written in VBA launguage.
Regards
Alan
Luis_Pacheco_3D
The code is a test to complement a bigger code, I fix it today,I just added these 3 lines, and works.
Dim oPlane1 As WorkPlane
Dim aDoc As AssemblyDocument = ThisApplication.ActiveDocument
Dim oPart As ComponentOccurrence
Thank you for your help.
