- Mute
- Permalink
- Report
I have a customer that has a linked parameter between an iPart Factory and another component in the assembly. The iPart is a piece of pipe and the part with a linked parameter is a lining for the pipe. The issue that I am facing is that the users have to open the pipe to get the lining to update. What I discovered is that the active pipe member in the assembly has to be the active member in the iPart Factory IPT. The reason for this, is that the needed member needs to be the active member in the factory so that the pipe broadcasts the correct ID to the lining.
We tried several approaches, including have iLogic open the member or the iPart Factory. We tried all kinds of code that would update. I am fairly certain that if I can use iLogic to set the needed row as the Default Row in the iPart Factory everything else will work. I am struggling to get iLogic to set the Default Row. I have seen sample code that shows that you need to have the Row Object to use the iPartFactory.DefaultRow function. I am certain that is what I have in my code now, but for some reason the code is not working. I continually get a message stating that it could not find the member.
I know that one solution would to be use iLogic to pass parameters from the pipe to the lining, but my customer would prefer not to use that approach.
I have built a simplified version of the scenario I am seeing, and will attach the file to this post (the sample was made in Inventor 2015). Any advice would be greatly appreciated.
Steve Olson
Manager, Training Services
https://knowledge.autodesk.com/profile/O37DF451BDD2485B
https://www.youtube.com/channel/UCgQTCawsuRFJVSHRXIwLdtg
