Set Default Printer Paper Size
isocam
isocam
Can anybody answer the following question???
I need to "Programatically", using Visual Studio, set the default printers paper size to either "A4" or "A3".
I have the following code that gets the required paper size ("A4" or "A3") from the registry and checks that the default printer supports "A3". If it does I want to set the paper size to "A3".
Can this be done????
Here is my code so far....
Imports Microsoft.Win32
Public Class Form1
    Private Sub Form1_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load
        Dim SetPaperSize As String
        Dim PrinterPaperSize As String
        SetPaperSize = My.Computer.Registry.GetValue("HKEY_CURRENT_USER\Software\MechTools\", "Printer Paper Size", "0")
        For Counter = 0 To PrintDialog1.PrinterSettings.PaperSizes.Count
            PrinterPaperSize = PrintDialog1.PrinterSettings.PaperSizes.Item(Counter).PaperName
            If PrinterPaperSize = SetPaperSize Then
                ' MsgBox(SetPaperSize) HERE IS WHERE I NEED THE CODE TO SET THE PAPER SIZE
                Exit For
            End If
        Next
        End
    End Sub
End Class
Many thanks in advance!!!
xiaodong_liang
Autodesk Support
Autodesk Support
Frankly, I did not understand what is your problem. I just copied the API sample here, where you can see how to set the paper size. Hope it helps.
Public Sub PrintDrawing()
    ' Set a reference to the print manager object of the active document.
    ' This will fail if a drawing document is not active.
    Dim oPrintMgr As DrawingPrintManager
    Set oPrintMgr = ThisApplication.ActiveDocument.PrintManager
    ' Get the name of the printer that will be used.
    If MsgBox("Using printer """ & oPrintMgr.Printer & """  Do you want to continue?", vbYesNo + vbQuestion) = vbNo Then
        ' Change to another printer.
        Dim sPrinterName As String
        sPrinterName = InputBox("Enter name of new printer:", "New Printer")
        If sPrinterName = "" Then
            Exit Sub
        Else
            oPrintMgr.Printer = sPrinterName
        End If
    End If
    ' Set to print in color.
    oPrintMgr.ColorMode = kPrintColorPalette
    ' Set to print two copies.
    oPrintMgr.NumberOfCopies = 2
    ' Set to print using portrait orientation.
    oPrintMgr.Orientation = kPortraitOrientation
    ' Set the paper size.
    oPrintMgr.PaperSize = kPaperSize11x17
    ' Set to print all sheets.
    oPrintMgr.PrintRange = kPrintAllSheets
    ' Set to print full scale.
    oPrintMgr.ScaleMode = kPrintFullScale
    ' Submit the print.
    oPrintMgr.SubmitPrint
    ' Change the number of copies to 1.
    oPrintMgr.NumberOfCopies = 1
    ' Change the paper size to a custom size.  The units are in centimeters.
    oPrintMgr.PaperSize = kPaperSizeCustom
    oPrintMgr.PaperHeight = 15
    oPrintMgr.PaperWidth = 10
    ' Get and set the current sheet range.
    Dim iFromSheet As Long
    Dim iToSheet As Long
    Call oPrintMgr.GetSheetRange(iFromSheet, iToSheet)
    MsgBox "Current sheet range is " & iFromSheet & " to " & iToSheet & Chr(13) & _
            "Setting to print sheets 1-2."
    ' Change the print range to print sheets 1 through 2.
    oPrintMgr.PrintRange = kPrintSheetRange
    Call oPrintMgr.SetSheetRange(1, 2)
    ' Submit the print.
End Sub
