SelectSet.Select method how to use?
Cris-Ideas
Advisor Advisor
Cris-Ideas
I have placed this on customisation forum but maybe someone hers can answer as well.
I have two subs in the form. But I am getting exception.
    Dim oComponentList As Inventor.SelectSet
    Dim compOcc As Inventor.ComponentOccurrence
    Dim obj As Object
Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click oComponentList = _invApp.ActiveDocument.SelectSet For Each obj In oComponentList Debug.Print(obj.Name) Next Dim oComponentList As Inventor.SelectSet Dim compOcc As Inventor.ComponentOccurrence Dim obj As Object End Sub Private Sub Button2_Click(sender As Object, e As EventArgs) Handles Button2.Click For Each obj In oComponentList Debug.Print(obj.Name) Next End Sub
It is the second button, first works ok.
What do I do wrong, or what I do not understand?
Can someone advice?
Cris.
Cris,
https://simply.engineering
johnsonshiue
Hi! Please refer to the similar thread on Inventor Customization forum.
https://forums.autodesk.com/t5/inventor-customization/selectset-select-method-how-to-use/m-p/8176774...
Many thanks!
Software Test Engineer
