Selecting a named face with ilogic
jake_pietrzak
jake_pietrzak
Hi Everyone, its been a while.
Recently I encountered a problem with my dxf exporter.
Can anyone help with selecting a named face in part or assembly with ilogic?
Accepted solutions (3)
jake_pietrzak
To Give you more context, this a bit of code I found (thanks @ClintBrown3D)
Dim doc = ThisApplication.ActiveDocument
Dim entity = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Select a Face to Export as DXF")
doc.SelectSet.Select(entity)
 But in here instead of typing the name of the face in part i need to click on it.
Does anyone has any idea how to pick face by name, not by clicking on it?
Thanks!
FINET_Laurent
Here is a quick code as an exemple :
Dim Doc As Inventor.Document = ThisApplication.ActiveDocument
Dim o As ObjectCollection = Doc.AttributeManager.FindObjects("*", "*", "Face2")
Dim obj As Object = o(1)
Dim f As Inventor.Face
f = DirectCast(obj, Face)
 Kind regards,
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
Curtis_W
Hi @jake_pietrzak
Assuming you've assigned the face a name as shown, you can select the face by it's name using something like this example.
I hope this helps.
Curtis
Dim oNamedEntities = iLogicVb.Automation.GetNamedEntities( ThisDoc.Document)
oFace = oNamedEntities.FindEntity("My Face")
ThisDoc.Document.SelectSet.Select(oFace)
jake_pietrzak
Thanks @Curtis_W  & @FINET_Laurent ,
This is very helpful and easy solution for my problem.
Exactly what I need.
Thanks again!
Ok, it works great, but I have another challenge for you 😉
Lets say I have Assembly called: Assembly 01 😉
In this assembly I have 3 parts called: Part 01, Part 02 & Part 03.
Parts: Part 01 & Part 02 have a face called: Face 01.
How can I  select Face 01 in each part from assembly level?
Curtis_W
Hi @jake_pietrzak ,
Here is a quick example for selecting the named faces in parts ( if the named face exists) from an assembly.
Dim oDoc As AssemblyDocument = ThisDoc.Document
Dim oOcc As ComponentOccurrence
Dim oFaceProxy As FaceProxy
fname = "Face 01"
For Each oOcc In oDoc.ComponentDefinition.Occurrences
	Dim oNamedEntities = iLogicVb.Automation.GetNamedEntities(oOcc.Definition.Document)
	If oNamedEntities.NameExists(fname) = False Then Continue For
	oFace = oNamedEntities.FindEntity(fname)
	oOcc.CreateGeometryProxy(oFace, oFaceProxy)
	ThisDoc.Document.SelectSet.Select(oFaceProxy)
Next
 I hope this helps.
Curtis
