SelectEvents.OnSelect not fired with kSketchProfileFilter in an assembly
stefanome
stefanome
If I open a part and I run my addin the InteractionEvents object allows me to select any type of entities, including profiles.
If I open an assembly containing the same part, enter the part editing on that part, and run my addin, all the selection filters but kSketchProfileFilter work well.
With kSketchProfileFilter when I move the mouse on an area I see the highlight, but when I click nothing happens.
When I right click, then click on Continue, InteractionEvents.OnTerminate is fired.
Stefano
stefanome
I am afraid this is a bug of Inventor 2012.
I tried this from the Immediate window of VBA:
ThisApplication.CommandManager.Pick kSketchProfileFilter, "Pick a feature"
It works if the part is open, it says "Automation error - Invalid pointer" if the assembly is open and the part is editing.
Is there a workaround?
Can I ask the user for a point, then use the point to get to the profile? I wouldn't get the nice highlight, but at least it would work.
Stefano
