Select plane of part
GeorgK
Advisor Advisor
GeorgK
Hello together,
how could I select a plane of a selected part and highlight it?
Thank you Georg
LukeDavenport
Hi GeorgK,
We'd need some more information I think. Do you have a occurrence and you want to select (highlight) a plane with a known name on that occurrence?
GeorgK
Hello Luke,
I would like to select two parts in an assembly. After that I have a form with the option to select the x, y or z plane of the parts and add a constraint with the distance between them.
Georg
adam.nagy
Autodesk Support
Autodesk Support
Hi Georg,
I hope this helps:
http://adndevblog.typepad.com/manufacturing/2014/09/select-plane-of-given-part-occurrence.html
Cheers,
Adam Nagy
Autodesk Platform Services
GeorgK
Hello Adam,
thank you very much.
Georg
