As expected, thanks Brian. This was a fairly big issue for a current
project.
Neil
"Brian Ekins (Autodesk)" wrote in message
news:BFDD675292343BC5EB40E61A5E4CF987@in.WebX.maYIadrTaRb...
> It will return occurrences directly owned by the
AssemblyComponentDefinition
> you got the ComponentOccurrences object from. This means it will only
> search that level of the assembly. It's also only within a single level
> that unique names are guaranteed, so if it expanded beyond this then you
> have those issues to contend with.
> Brian Ekins
> Developer Technical Services, Autodesk
> Discussion Q&A: http://www.autodesk.com/discussion
> "Neil Munro" wrote in message
> news:DCA3C04EF2F9803997BF8EBAA3BCD403@in.WebX.maYIadrTaRb...
> > Will the ItemByName property (method?) return a "name path" to uniquely
> > identify a leaf component in a subassembly (which will have the same
> browser
> > name as the same leaf part in all subassembly occurrences), or will you
> need
> > to step through the ItemByName property up and down the hierarchy?
> > Thanks,
> > Neil
> > news:D2E34009255EE7699B87A1F7244FE87A@in.WebX.maYIadrTaRb...
> > > The technique you're currently using is the best way to do this.
> Indexing
> > a
> > > part by name was not previously supported because unique names were
not
> > > enforced for occurrences in an assembly. This changed in Inventor 7.
> > > Inventor 8 will introduce a new property (ItemByName) on the
> > > ComponentOccurrences object that will allow you to obtain a specific
> > > occurrence given its name.
> > > Brian Ekins
> > > "Michel QUERIAUD" wrote in message
> > > news:8E9B8BDEEFA20E866EA0A72928CBAD6B@in.WebX.maYIadrTaRb...
> > > > Hi,
> > > > Is there an easiest way to select an occurence by it's name :
> > > > Sub EraseOccurence(OccurenceName As String)
> > > > Dim Occurence As ComponentOccurrence
> > > > For Each Occurence In oAsmDoc.ComponentDefinition.Occurrences
> > > > If Occurence.Name = OccurenceName Then
> > > > Occurence.Visible = False
> > > > Exit For
> > > > End If
> > > > Next Occurence
> > > > End Sub
> > > > It's so slow with large assemblies !
> > > > Thanks,
> > > > Michel QUERIAUD
