Select input data ilogic
mayla_difrancesco
mayla_difrancesco
I have 3 input data: incl_sca, n_grad, lun_piano. The data is selected through drop-down windows, one for each input data:
incl_sca = InputListBox("Scegliere inclinazione scala", MultiValue.List("incl_sca"), incl_sca, "Inclinazione scala")
n_grad = InputListBox("Scegliere numero gradini", MultiValue.List("n_grad"), n_grad, "Numero gradini")
lun_piano = InputListBox("Scegliere lunghezza piano", MultiValue.List("lun_piano"), lun_piano, "Lunghezza piano")
Is there a way to select all the data with a single window?
marcin_otręba
you can make form with this 3 parameters on it
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
mayla_difrancesco
Thanks. Where can I find it in ilogic inventor 2025?
marcin_otręba
you can start from this:
Inventor 2024 Help | Form Editor Reference | Autodesk
mayla_difrancesco
I don't want to use forms. Is there a specific ilogic command to do that?
marcin_otręba
no there is not.
