Home Tab Opening via VB Script / VBA
georg_hartmannV6HPW
georg_hartmannV6HPW
I ran into a littel caveat with my code, that opens my CAD Files.
It is a little plugin for an UML Modeler, that can open corresponding CAD Files, if i have the file path.
It generates a CMD Command to run :
cscript //Job:fileOpener CADInterface.wsf CAD_filepath
and the job script inside looks like :
Dim InvApp, InvDoc
Dim fso, fullPathToFile,strFileName
Sub main()
	'On Error Resume Next
    wscript.Echo(">>> FileOpener v1  <<<")
    ' Initialize Inventor
    set InvApp = CreateObject("Inventor.Application")
    InvApp.Visible = True
    ' Generate absolute filepath to CAD-File
    strFileName = Wscript.arguments(0)
    set fso = CreateObject("Scripting.FileSystemObject")
    fullPathToFile = fso.GetAbsolutePathName(strFileName)
    Set InvDoc = InvApp.Documents.open(fullPathToFile,true)
'InvApp.UserInterfaceManager.ResetRibbonInterface()
'InvApp.UserInterfaceManager.Ribbons.Item("Part")
 '   InvApp.UserInterfaceManager.Update
  '  InvApp.UserInterfaceManager.ActivateTab("Id_Part")
End Sub
This in itself works like a charm , but it does not open the home Tab in inventor 2024, which in turn means, that i have no control over the part or make adjustments.
I could click it every time, but it would be great , if i can open it automatically.
Can this be done ?
Best Regards
Georg
WCrihfield
Hi @georg_hartmannV6HPW.  I am not sure if there is any true Inventor API way to show Inventor's 'Home' tab, but I suspect that we could show it by executing the proper 'command' (ControlDefinition) for showing it that gets executed when we click that button in the user interface.  I do not recall that exact command name, but I think it was either "AppShowHomeBaseCmd" or "FWxInventorHomeCmd".
ThisApplication.CommandManager.ControlDefinitions.Item("commandName").Execute()
Wesley Crihfield
(Not an Autodesk Employee)
tim11_manhhieu
ThisApplication.CommandManager.ControlDefinitions.Item("AppShowHomeBaseCmd").Execute()
