Select a view with ilogic view
Hi All,
Can anyone tell me how can I select a view in an idw file, please?.
I refer to do visible that selection,the same when I select a view in a drawing and it appears framed in a red lines as I show you in the screenshot.Selected view.jpg
Can you help me, please?.
Thanks.
Sergio.D.Suárez
Dim doc As DrawingDocument = ThisDoc.Document
Dim oSheet As Sheet = doc.ActiveSheet
Dim oView As DrawingView = oSheet.DrawingViews.Item(1)'Select View for Item number
ThisApplication.CommandManager.DoSelect(oView)'Select View
Hi, this code will select an identified view through the item in the active drawing file sheet.
I hope I can help you with your problem. regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Muchas gracias, Sergio, Smiley Happy
Thank you very much.
RoyWickrama_RWEI
Hi Sergio.
Thanks. I like it: useful in my iLogic pursuits.
could I have know the code for picking a view (with a pick enum filter)? Useful, in case there ate multiple views.
Thanks.
Sergio.D.Suárez
Hi @RoyWickrama_RWEI , try these ilogic codes, either one, these fragments I use it a lot, I hope they can be useful, regards
oView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select View")
 Or
oView = ThisApplication.CommandManager.Pick(16898, "Select View")
Mechanical Designer
Matthew_Policelli
Is there a way to select multiple views using this (while holding ctrl, for example)?
