Select a view and change custom iproperty of its part
mohandis2
mohandis2
Can anyone help with ilogic that asks to select a view (containing part), and change a custom iproperty of that part?
WCrihfield
Here is one possible way to do it.  Just edit the name and value.
Dim oView As DrawingView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select a drawing view of part.")
If oView Is Nothing Then Return
Dim oViewDoc As Inventor.Document = oView.ReferencedDocumentDescriptor.ReferencedDocument
Dim oViewDocCProps As Inventor.PropertySet = oViewDoc.PropertySets.Item(4)
Dim oViewDocCProp As Inventor.Property = Nothing
Try
	oViewDocCProp = oViewDocCProps.Item("Name Of Custom iProperty")
	oViewDocCProp.Value = "Value Of Custom iProperty"
Catch
	'oViewDocCProp = oViewDocCProps.Add("Value Of Custom iProperty", "Name Of Custom iProperty")
End Try
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
(Not an Autodesk Employee)
mohandis2
it works, thanks
but It applies for all model states
how can I change it to apply for a selected model state (or active model state) ?
Thanks again.
WCrihfield
Hi @mohandis2.  As you may, or may not know, when multiple ModelStates are involved, the code gets much more complicated.  Below is another version of an iLogic rule for this task, but it also includes some extra code for when the view is of a model that may (or may not) have 2 or more ModelStates in it, and you just want to change the value of a custom iProperty that already exists.  I like to use the ModelStateTable for changing values of things that already exist, but it will not allow us to add new columns to it by code for when we may want to create a new UserParameter or custom iProperty.  There are various ways to do this, but they are all a lot more complex than they used to be before ModelStates were involved.
Dim oSheet As Inventor.Sheet = oView.Parent
Dim oDDoc As DrawingDocument = oSheet.Parent
If oDDoc.RequiresUpdate Then oDDoc.Update2(True)
oSheet.Update
Dim oRDD As DocumentDescriptor = oView.ReferencedDocumentDescriptor
If oRDD.ReferenceMissing OrElse oRDD.ReferenceDisabled Then
	MsgBox("This view's reference is either missing or disabled.  Exiting routine.", vbCritical, "iLogic")
	Return
'If oRDD.ReferencedModelState = ModelStateTypeEnum.kCustomModelStateType Then
Dim oViewDoc As Inventor.Document = oRDD.ReferencedDocument
If oViewDoc.RequiresUpdate Then oViewDoc.Update2(True)
Dim sViewMS As String = oView.ActiveModelState 'can be Null
If String.IsNullOrEmpty(sViewMS) Then
	Logger.Info("This view's active ModelState specification is either null or empty.")
Dim oMSs As ModelStates = Nothing
Try : oMSs = oViewDoc.ComponentDefinition.ModelStates : Catch : End Try
If oMSs Is Nothing OrElse oMSs.Count < 2 Then
	'there are no ModelSates, or only the 1 original involved, so do things normally
	Try
		oViewDocCProp = oViewDocCProps.Item("CustomPropertyName")
		oViewDocCProp.Value = "CustomPropertyValue"
	Catch
		Logger.Error("Error getting custom iProperty, or setting its value.")
	End Try
Else 'there are 2 or more ModelSates involved, so do things the hard way
	'make sure we have a reference to the 'factory' document (the only version that is not ReadOnly)
	Try : If oViewDoc.ComponentDefinition.IsModelStateMember Then _
		oViewDoc = oViewDoc.ComponentDefinition.FactoryDocument
	Catch : End Try
	Dim oMSTable As ModelStateTable = oMSs.ModelStateTable
	Try
		'get the row for the view's active ModelState
		Dim oMSRow As ModelStateTableRow = oMSTable.TableRows.Item(sViewMS)
		'get the column for the custom iProperty (we must include which PropertySet it is in)
		Dim oMSCol As ModelStateTableColumn = oMSTable.TableColumns.Item("CustomPropertyName [Custom]")
		'set the value of the Cell at the intersection of that row and that column
		oMSRow.Item(oMSCol).Value = "CustomPropertyValue"
	Catch
		Logger.Error("Error editing ModelStateTable to change custom iProperty value.")
	End Try
oSheet.Update
Wesley Crihfield
