Section View Alignment
I have certain Section Views that don't automatically update their alignment when the part is changed. I can manually pick the view and hit the update button and it re-aligns itself to it's base view.
Is it possible to do this using VB?
Hello jimpe,
Did you try "ThisApplication.ActiveDocument.Update"?
/Adam
> alignmen
> updat
Hello Adam,
Yes, I tried that. This idw has 4 sheets and the section view in question is on sheet 4. The update button in the toolbar is "grayed-out" until I manually select a view. Then I am able to hit the update button and it re-aligns itself. Somehow, using VB, I need to select the view and then find out what the code is to invoke the update.
