Section & Detail View Label
Talayoe
Message 1 of 14
Talayoe
Good afternoon all,
I am working with a large drawing package (for me at least) that is 36 pages long, 25 or so different parts for the build.
What I dont care for is that the detail view labels are incrementing thru the entire drawing package and I would rathe have it sheet by sheet, if possible.
Example:
Drawing Sheet 1: I create 3 section views, it auto labels then A-A, B-B, C-C, ect.
Drawing Sheet 2: I create a single (or more) section views it currently labels them D-D, ect whereas I would like it to start over at A-A.
Is this possible?
For the sake of the package by the time I will be done with it I will have so many section views/detail views labels that I will be in CZ-CZ likely.
Tks!
-Randy
Inventor 2017 PDS
Replies (13)
Message 2 of 14
SharkDesign
You could probably write iLogic code to do this, but there isn't a standard command for this.
  Inventor Certified Professional
Message 3 of 14
Talayoe
Hi James,
I did find another post with an iLogic code to rename them incrementally thru the entire drawing. Works well, keeps them in order, but still on the increment status. Not a huge deal, but it would still be nice to have broken up by drawing, like revision numbers can be.
Thanks for the quick reply/thot!
-Randy
Inventor 2017 PDS
Message 4 of 14
jtylerbc
If you make each sheet as a separate drawing file, they will each have their own labeling sequence starting at A-A.
You get one sequence per drawing file, so other than manual relabeling (or iLogic/VBA automating the manual relabeling process), breaking it up into individual files is the only way to get what you want.
Message 5 of 14
theo.bot
This Rule will rename all Section, Detail, Auxiliary and Projected views with a broken alingment. By default the rule will restart with the view names for each sheet. But for those who would like to have this for the entire document, simply change the RestartperSheet to False.
Dim oDoc As DrawingDocument
oDoc = ThisDoc.Document
Dim oSheet As Sheet
Dim oView As DrawingView
Dim oLabel As String
Dim RestartperSheet As Boolean
'Set this value to False if you want te rename views for all sheets
'Set this value to True if you want to rename views per sheet
RestartperSheet = True
'Set Start Label
oLabel = "A"
For Each oSheet In oDoc.Sheets
	'If True Set label Start Value per sheet
	If RestartperSheet = True
		oLabel = "A"
	End If
	For Each oView In oSheet.DrawingViews
		Logger.Info(oView.ViewType & " " & oView.Name)
		Select Case oView.ViewType
			Case kSectionDrawingViewType
				'Set view name to Label
				oView.Name = oLabel
				'Set Label to next character
				oLabel = Chr(Asc(oLabel) + 1)
			Case kAuxiliaryDrawingViewType
				oView.Name = oLabel
			Case kDetailDrawingViewType
				oView.Name = oLabel
			Case kProjectedDrawingViewType
				If oView.Aligned = False Then
					oView.Name = oLabel
				End If
		End Select
	Next
Next
Message 6 of 14
Talayoe
Thank you so much, that is EXACTLY what I was looking for! 🙂
-Randy
Inventor 2017 PDS
Message 7 of 14
matthew.wrightSCX
This is great, however be aware that it will need tweaking to avoid the use of letters "I" & "O" as part of drawing standards.
Message 8 of 14
theo.bot
@matthew.wrightSCX ,
You're right, I should have added that 😉
here a new version that includes the check, if in the drawing standard "view Names" are enabled in the "apply to" section it will check the list.:
Dim oStyleM As DrawingStylesManager
oStyleM = oDoc.StylesManager
Dim oStandard As DrawingStandardStyle
oStandard = oStyleM.ActiveStandardStyle
Dim oSheet As Sheet
RestartperSheet = False
'Set Start Label
oLabel = "A"
		oLabel = "A"
	End If
		'Exclude Charater from standard style list
		If oStandard.ApplyExcludeCharactersToViewNames = True Then
			While oStandard.ExcludeCharacters.Contains(oLabel) = True
			End While
		End If
				oView.Name = oLabel
				oView.Name = oLabel
				oView.Name = oLabel
					oView.Name = oLabel
				End If
		End Select
	Next
Next
iLogicVb.UpdateWhenDone = True
Message 9 of 14
gflessasP4B6Q
Hey @theo.bot, I know that its been a few years since you wrote this.
I've started using this code and its very helpful, however I'm running into an issue where when it gets to the end of the alphabet, instead of going to AA, it uses characters like /, and [.
Is it possible to tweak your code to switch to AA, AB, AC, etc?
Message 10 of 14
daltonNYAW9
I had the same problem. Add the following function and replace these lines:
Link to solution
Replace
 With
oLabel = GetAlphaString(oLabel)
 The function increases the label value every time it is called
Public Function GetAlphaString(ByVal ColumnLetter As String) As String
	'convert to number
	For i = 1 To Len(ColumnLetter)
		AlphaNum = AlphaNum * 26 + (Asc(UCase(Mid(ColumnLetter, i, 1))) -64)
	Next
	AlphaNum = AlphaNum + 1
	'convert back to format
	Do While AlphaNum > 0
		AlphaNum = AlphaNum - 1
		GetAlphaString = ChrW(65 + AlphaNum Mod 26) & GetAlphaString
		AlphaNum = AlphaNum \ 26
	Loop
End Function
Message 11 of 14
jacobWN5VK
ignore this
Message 12 of 14
mathew_kenney
Hi there. I was looking to use the above code but with the change of using numbers for the detail views and letters for section, auxillary etc.
How would I do this? Thanks
Message 13 of 14
gho.ghorbani
Hi there
use this code
Sub Main()
    Dim oSheet As Sheet
    ' Set this value to True to rename views per sheet, False for continuous labeling across all sheets
    ' Set Start Label
    oLabel = "A"
        ' Reset label to A for each sheet if RestartperSheet is True
        If RestartperSheet = True Then
            oLabel = "A"
        End If
            ' Skip excluded characters for the current label
                    oLabel = GetNextLabel(oLabel, oStandard)
                End While
            End If
                    ' Set view name to Label
                    oView.Name = oLabel
                    ' Get next valid label
                    oView.Name = oLabel
                    oView.Name = oLabel
                        oView.Name = oLabel
                    End If
            End Select
        Next
    Next
End Sub
' Function to get the next valid label (A-Z, skipping excluded characters)
Function GetNextLabel(currentLabel As String, oStandard As DrawingStandardStyle) As String
    Dim nextLabel As String
    nextLabel = Chr(Asc(currentLabel) + 1)
    ' Ensure label stays within A-Z (ASCII 65-90)
    If Asc(nextLabel) > Asc("Z") Then
        nextLabel = "A" ' Reset to A if exceeding Z
    End If
        While oStandard.ExcludeCharacters.Contains(nextLabel) = True
            nextLabel = Chr(Asc(nextLabel) + 1)
            End If
        End While
    End If
    GetNextLabel = nextLabel
End Function
Message 14 of 14
jacob_r_kane
Can we get this in VBA please?
