Hi @blandb. I have not heard anything yet about if Autodesk changed any default rule running order or auto run behavior. But there are a couple of quick settings you can check within those rules. When you have the rule editor dialog open (to edit those rules), click on the Options tab then check which settings you have checked/unchecked. Sounds similar to a couple of those settings: 'Fire Dependent Rules Immediately', and 'Don't Run Automatically'. Those settings are saved within each rule, so you would have to check each rule. If that's not it, you can check out the various settings within the iLogic Add-In's Automation area by typing in "iLogicVb.Automation." somewhere within a rule, then exploring the available stuff there. There are 3 things about 'delayed rule running mode'. You can Get/Set the 'RuleRunningOrderOption'. RulesEnabled, RulesOnEventsEnabled, etc. And if working with the Event Triggers, you can also check out the Options button within that dialog. (The settings within that dialog will overrule the similar sounding settings within iLogicVb.Automation that you can acces by code.)
I'm still using Inventor 2022.2.2, but I know that I can have a lot of rules within a document without any of them automatically running, if I don't want them to, even without suppressing them. If I don't have any of those rules listed within the Event Triggers, and don't have any unquoted local parameter names within any of them, then they generally won't run automatically. Since I tend to use external iLogic rules and global iLogic forms for the vast majority of my automation, what I will often do to benefit from local document triggering behavior is create a very simple local rule that just runs an external rule. Then that external rule will either have my main code, or it will simply contain instructions to run a series of other external rules in the order I choose, to have more control.
Wesley Crihfield
(Not an Autodesk Employee)
