Most of the code below I took from this blog post "Automatically generate overall dimensions". (Here I use the first drawing view on the active sheet. That is different from your code.) It has a function to get all intent points of a view. That list includes the bottom point. With a sorting function, you can get the bottom intent and use it in your sketch.
Public Class ThisRule
Private _doc As DrawingDocument
Private _sheet As Sheet
Private _view As DrawingView
Private _intents As List(Of GeometryIntent) = New List(Of GeometryIntent)()
Sub Main()
_doc = ThisDoc.Document
_sheet = _doc.ActiveSheet
_view = _sheet.DrawingViews.Item(1)
CreateIntentList()
CreateLowestPointLine()
End Sub
Private Sub CreateLowestPointLine()
Dim orderedIntents = _intents.OrderByDescending(Function(s) s.PointOnSheet.Y)
Dim intentBottom = orderedIntents.Last
Dim sketch As DrawingSketch = _view.Sketches.Add()
sketch.Edit()
Dim bottomSketchPoint As Point2d = sketch.SheetToSketchSpace(intentBottom.PointOnSheet)
Dim sketchPointEnd As Point2d = ThisApplication.TransientGeometry.
CreatePoint2d(bottomSketchPoint.X - 5, bottomSketchPoint.Y)
sketch.SketchLines.AddByTwoPoints(bottomSketchPoint, sketchPointEnd)
' If you need the SketchEntity to constraint your line then you can get it like this:
' Dim entity As SketchEntity = sketch.AddByProjectingEntity(intentBottom.Geometry)
sketch.ExitEdit()
End Sub
Private Sub CreateIntentList()
For Each oDrawingCurve As DrawingCurve In _view.DrawingCurves
Select Case oDrawingCurve.ProjectedCurveType
Case _
Curve2dTypeEnum.kCircleCurve2d,
Curve2dTypeEnum.kCircularArcCurve2d,
Curve2dTypeEnum.kEllipseFullCurve2d,
Curve2dTypeEnum.kEllipticalArcCurve2d
addIntent(oDrawingCurve, PointIntentEnum.kCircularTopPointIntent, True)
addIntent(oDrawingCurve, PointIntentEnum.kCircularBottomPointIntent, True)
addIntent(oDrawingCurve, PointIntentEnum.kCircularLeftPointIntent, True)
addIntent(oDrawingCurve, PointIntentEnum.kCircularRightPointIntent, True)
addIntent(oDrawingCurve, PointIntentEnum.kEndPointIntent, False)
addIntent(oDrawingCurve, PointIntentEnum.kStartPointIntent, False)
Case _
Curve2dTypeEnum.kLineCurve2d,
Curve2dTypeEnum.kLineSegmentCurve2d
Case _
Curve2dTypeEnum.kPolylineCurve2d,
Curve2dTypeEnum.kBSplineCurve2d,
Curve2dTypeEnum.kUnknownCurve2d
' Unhandled curves types
Case Else
End Select
Next
End Sub
Private Sub addIntent(Geometry As DrawingCurve, IntentPlace As Object, onLineCheck As Boolean)
Dim intent As GeometryIntent = _sheet.CreateGeometryIntent(Geometry, IntentPlace)
If intent.PointOnSheet Is Nothing Then Return
If onLineCheck Then
If (IntentIsOnCurve(intent)) Then
_intents.Add(intent)
Else
End Sub
Private Function IntentIsOnCurve(intent As GeometryIntent) As Boolean
Dim Geometry As DrawingCurve = intent.Geometry
Dim sp = intent.PointOnSheet
Dim pts(1) As Double
Dim gp() As Double = {}
Dim md() As Double = {}
Dim pm() As Double = {}
Dim st() As SolutionNatureEnum = {}
pts(0) = sp.X
pts(1) = sp.Y
Try
Geometry.Evaluator2D.GetParamAtPoint(pts, gp, md, pm, st)
Catch ex As Exception
Return False
End Try
Return True
End Function
End Class
Jelte de Jong
Blog: hjalte.nl - github.com
